Hey Argent Paint Do It Your Selfers Want To Save Money? #31945
11/07/06 02:08 AM
11/07/06 02:08 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I just picked some of this stuff up at Ace Hardware to spray some lawn furniture, I did not expect it to be glittery, I thought I was buying a textured satin black. When I sprayed some of this on a test panel next to some Dark Argent paint that Totally Auto sent me it was a DEAD ON match! The Krylon is super cheap as compared to the TA stuff so it's a way you can save money if you plan to paint your own stuff. They also had a light silver argent mix, it also matched TA's paint, I'd guess it has to be the same supplier to be so close.
*BTW, NIETHER what TA or the Krylon sells is a perfect match to vintage original Dark or Silver Argent, for that you'll need the good stuff sold by AllTrim Specilaties or Roger Gibson, but for street/driver quality cars this rattle can stuff will be ok for most.
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: ScottSmith_Harms] #31946
11/07/06 02:22 AM
11/07/06 02:22 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
isnt it nice when something works that doesnt cost a buttload I found another Krylon product, semi-flat black in their "rust tough" line. I use it for painting chassis parts
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: ScottSmith_Harms] #31947
11/07/06 08:03 AM
11/07/06 08:03 AM
places
79powerwagon Offline
places
Have you looked at the Rustoleum line of plastic paints yet? I painted a dark blue plastic console for my Bronco so it would match my light chestnut interior. Rustoleum's "Nutmeg" finish was a dead-on match for the Ford color AND gloss! You have to use their plastic primer before the paint, but it holds up quite well! For those of you needing to refinish some of your interior plastic parts, it's worth considering!
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: 79powerwagon] #31948
11/07/06 09:03 AM
11/07/06 09:03 AM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
Would the Rustoleum or Krylon plastic paints work on the black gauge housing?
Mine needs a touch up, and I was wondering what to use?
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: nomore65BelvJim] #31949
11/07/06 09:34 AM
11/07/06 09:34 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That stuff is Awesome! I love how it dries to the touch in all of about 4 minutes!
I've used it on a ton of parts already!
**Photobucket sucks**
Re: Hey Argent Paint Do It Your Selfers Want To Save Mo [Re: CUDAJAS] #31950
11/08/06 09:44 PM
11/08/06 09:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Pretty much any quick drying rattle can paint will work on your housing. The material the housing is made of is a blend of ABS (a styrene blend) it's one of the easier plastics to paint with good results. Caution though, use a VERY good degreaser before you paint, any Armorall or silicone based protectants that may have been wiped on the dash will cause MAJOR fish eye problems if you paint over the stuff.
Re: Hey Argent Paint Do It Your Selfers Want To Save Mo [Re: ScottSmith_Harms] #31951
11/08/06 10:29 PM
11/08/06 10:29 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Kewl post. the back of my cuda will need a butt load of it.
I’m listening.
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: 70Cuda383] #31952
11/09/06 12:40 AM
11/09/06 12:40 AM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Great tip Scott! Thanks.
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: BADBEE] #31953
11/09/06 12:49 AM
11/09/06 12:49 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Does anybody know how they redo the 68-70 rallye dash gauges. like the actual trim pieces(68 vertical lines, 69 pebble texture) I definetely can't afford to pay 465 for just a few plastic pieces, but i would like for it to look a little nicer than it's current state??
Re: Hey Argent Paint Do It Your Selfers Want To Save Mo [Re: ScottSmith_Harms] #31954
11/09/06 08:33 AM
11/09/06 08:33 AM
CUDAJAS Offline
CUDAJAS  Offline
Thank you sir!
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: ScottSmith_Harms] #31955
11/09/06 09:46 AM
11/09/06 09:46 AM
Port Reading, NJ
roadrunner7070 Offline
Port Reading, NJ
Nice find!
Re: Hey Argent Paint Do It Your Selfers Want To Save Money? [Re: roadrunner7070] #31956
11/09/06 10:37 AM
11/09/06 10:37 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good info, to the archive it goes
