Re: 521 progress
[Re: AndyF]
#3192378
11/21/23 10:44 AM
11/21/23 10:44 AM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
What is the Bore and stroke of that 521?
With fords especially big ports want high compression and a big cam....and without both you can't have either.... but it'll still run well with lower compression as long as the cam is on the small side too.
Re: 521 progress
[Re: AndyF]
#3192503
11/21/23 07:29 PM
11/21/23 07:29 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
That'll be a fun build, and it is impressive how big you can go with the later model blocks, I think it's something like 557" without too much trouble.. Like you said, they put them in everything- 429's and 460's in vans, pickups, the medium duty F600/700, you name it, all through the 90's.
Re: 521 progress
[Re: AndyF]
#3192512
11/21/23 08:24 PM
11/21/23 08:24 PM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
4.390 bore x 4.300 stroke. I'm not too worried about the combination. We're using the parts that Kaase recommends and he has built a ton of these engines. Once we get some dyno time on it we'll start trying different things but the first build will follow the Kaase plan. The cam is his "small" one since we have a smaller engine, but the duration at 0.400 is 91 degrees so the intake valves are open more than 0.700 for a quarter rotation of the engine. Andy, this 460 motor has interested me for years. My very first thought was a fabricated tunnelram and twin throttle bodies, running e85 would make a dynomite combo, especially if the 557 size is not too tough to do. A local racer / engine builder runs 598 cube 385 series Fords, dialing 7.80 in the 1/4 on gasoline. One of my last outings i was unlucky enough to race him, and he went 7.80 on a 7.80 dial.
Re: 521 progress
[Re: gregsdart]
#3192579
11/22/23 10:32 AM
11/22/23 10:32 AM
Posts: 4,066 Mo.
racerx
Mo.
On Kasse web site, possible 659 cu in combo, 4.70 bore 4.75 stroke. Is that current pricing?
Re: 521 progress
[Re: racerx]
#3192704
11/22/23 07:25 PM
11/22/23 07:25 PM
Blusmbl
Plymouth, MI
On Kasse web site, possible 659 cu in combo, 4.70 bore 4.75 stroke. Is that current pricing? Looks like yes. A Ford Performance 460X block at Summit is $3300 as well, there are multiple BBF cast iron options at the $3k-ish price point. There is no reason a Callies MP cast iron block is $6500 (hey, it's on sale this week for $6000 at Mancini's!).
Re: 521 progress
[Re: Blusmbl]
#3192781
11/23/23 02:23 AM
11/23/23 02:23 AM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
Looks bad ass! I don't know anything about the intake manifolds but if you think what you have will hold it back, maybe send it to John Marcella? I've not needed his services so can't speak from experience but his work from photos looks truly amazing.
Re: 521 progress
[Re: 451Mopar]
#3194101
11/29/23 09:41 AM
11/29/23 09:41 AM
Blusmbl
Plymouth, MI
I watch way too much youtube, but Mike Finnegan had John Kaase rebuild the Hemi in his '55 Chevy and he did not have good luck with them at all. Some of that could've been Kaase not being familiar with hemis though.
Re: 521 progress
[Re: AndyF]
#3194125
11/29/23 11:18 AM
11/29/23 11:18 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What installed height are the springs set up at?
What’s the available installed height?
Is the vehicle the engine is going in destined for some street duty?
Personally, I don’t see a set of Manley 221443’s being the hot set up for nearly .800 lift with typical BB valvetrain weight components………. Unless the cam uses very tame ramps, and can function properly with whatever spring force you’d end up with by installing them at 1.250”+ net lift.
There are several more spring choices that facilitate .800-ish lift if you can get the IH closer to 2.00”.
Re: 521 progress
[Re: AndyF]
#3194141
11/29/23 12:13 PM
11/29/23 12:13 PM
fast68plymouth
So. Burlington, Vt.
A few minutes with a spring tester and you should be able to determine if the springs are suitable.
For that application(and what you’re doing with the engine), if you can get close to 2” IH, I’d probably go with something like a PAC-1225.
I haven’t used “tons” of Manley springs…….but more than a few sets. Nothing stands out in my memory with any of them being way out of spec…….but anything is possible.
Re: 521 progress
[Re: AndyF]
#3194170
11/29/23 01:42 PM
11/29/23 01:42 PM
Posts: 16,923 NC
440Jim
NC
I did have this issue before with dual conical springs from Comp. They told me to use the dual conicals for a solid roller cam but the catalog says they are only 150 on the seat. We went ahead and got the dual conical springs and they measured 200 on the seat, plenty on the nose and the coil bind was just right. So the guy was right, the catalog was wrong and the springs worked great in that engine. That is odd that the actual vs catalog are that far off. But since you have the springs, test them for pressure and coil bind height and see if Kaase is right or wrong. I would use 0.060" before coil bind for my calc.
Re: 521 progress
[Re: Blusmbl]
#3194180
11/29/23 02:22 PM
11/29/23 02:22 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Oh, there's a reason! Just not a reason anyone here likes or can agree with lol........ Personally I've drooled over the 200 dollar core 460s on marketplace, but feel like I picked my poison decades ago. It was already one level of dumb to do a Hemi, it'd be an entirely different level to change brands.
Rich H.
Esse Quam Videri
Re: 521 progress
[Re: ZIPPY]
#3194196
11/29/23 04:12 PM
11/29/23 04:12 PM
Posts: 31,001 Oregon
AndyF
Oh, there's a reason! Just not a reason anyone here likes or can agree with lol........ Personally I've drooled over the 200 dollar core 460s on marketplace, but feel like I picked my poison decades ago. It was already one level of dumb to do a Hemi, it'd be an entirely different level to change brands. I got divorced, sold my house and shop, moved, got a new shop and bought a new house all in the last 12 months so changing engine brands is not a big deal in the grand scheme of things!
Re: 521 progress
[Re: AndyF]
#3194204
11/29/23 04:29 PM
11/29/23 04:29 PM
ZIPPY
S.E. Michigan
Oh, there's a reason! Just not a reason anyone here likes or can agree with lol........ Personally I've drooled over the 200 dollar core 460s on marketplace, but feel like I picked my poison decades ago. It was already one level of dumb to do a Hemi, it'd be an entirely different level to change brands. I got divorced, sold my house and shop, moved, got a new shop and bought a new house all in the last 12 months so changing engine brands is not a big deal in the grand scheme of things! The desire and the means need to exist first: Neither one does Regardless, glad to hear you were able to move on when you needed to. You've been offloading stuff for quite awhile and have made a few comments here and there about "losing the shop" that seemed too serious to be a parody of reality TV show script.
Rich H.
Esse Quam Videri
Re: 521 progress
[Re: AndyF]
#3205961
01/18/24 04:19 PM
01/18/24 04:19 PM
fast68plymouth
So. Burlington, Vt.
Andy, what did the RR work out to be with the full spring load?
Re: 521 progress
[Re: AndyF]
#3206122
01/19/24 09:30 AM
01/19/24 09:30 AM
Posts: 4,045 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Figured the top end was ready to go together but discovered that the Cometic gaskets that Kaase recommended overhang into the combustion chambers. They said use 4.500 bore gaskets which seemed safe with a 4.390 bore size, but the chambers in the head are so big that the gasket overhangs near the exhaust valve. Evidently Kaase runs it that way but the engine builder I'm working with said to order new gaskets. So I got a set of 4.600 gaskets ordered from Summit.
If I get a chance to do another engine I think I'll buy the 4.500 bore block from Ford and build a 4.500 x 4.500 engine with the same exact heads. Be interesting to see the comparison between the two. The Ford blocks are available for $3900 which seems like an okay price. A few things here just seem ODD with the advice coming out of Kaase. I don't know how many "Ford" people builds there are to gage the success on what seems to be bad direction. But I'd be doing the things you are despite recommendations otherwise. I've seen some of the pieces here and there and appreciate the packages and prices Kaase offers so, I like you are sharing this build. There are engine build things that translate to any platform. I'd be curious to know actual NET lift as well to see where the springs are from c/b. Can you share the entire cam profile to gage its intensity?
Re: 521 progress
[Re: AndyF]
#3206194
01/19/24 01:36 PM
01/19/24 01:36 PM
fast68plymouth
So. Burlington, Vt.
Andy did you plot out the cam at all? Wondering if you had a duration @.200 number.
Re: 521 progress
[Re: 451Mopar]
#3206237
01/19/24 03:20 PM
01/19/24 03:20 PM
HardcoreB
Shelby Twp. Mi
Sounds like the wrong spring for a 0.800" lift cam. 1.950" install height and 1.170" coil bind is only 0.780" lift? Do they want them installed at a higher install height like 2.00"? I wouldn't think so as 235 seat pressure @1.950", and 535 lb/in rate seem fairly low pressures for such a large cam? Reviewing this thread after looking at that cam card I wouldn't run so little a spring even if the valves were titanium. I'd guess it'll float the valves before 6000rpm.
Re: 521 progress
[Re: fast68plymouth]
#3206271
01/19/24 05:05 PM
01/19/24 05:05 PM
AndyF
Andy did you plot out the cam at all? Wondering if you had a duration @.200 number. When I checked the intake lobe I measured 267@050, 197@200 and 90@400. But that was early in the build during a mockup session. Numbers could be slightly off due to a temp setup. Exhaust was 202@200 and 92@400
Re: 521 progress
[Re: HardcoreB]
#3206274
01/19/24 05:11 PM
01/19/24 05:11 PM
AndyF
Sounds like the wrong spring for a 0.800" lift cam. 1.950" install height and 1.170" coil bind is only 0.780" lift? Do they want them installed at a higher install height like 2.00"? I wouldn't think so as 235 seat pressure @1.950", and 535 lb/in rate seem fairly low pressures for such a large cam? Reviewing this thread after looking at that cam card I wouldn't run so little a spring even if the valves were titanium. I'd guess it'll float the valves before 6000rpm. We'll keep an eye on it. I've run those springs before with cams like this and haven't had an issue. I used the same spring in my old 514 dyno mule with 1.80 rocker arms and it pulled past 7000 rpm without any issue. That engine had Jesel rocker arms and 7/16 dual taper pushrods. This engine has T&D rockers and the same pushrods. The pushrods are literally the same ones. I sent them back to Smith Bros and had them cut down and replaced the cup with a ball. Saved me $400 over a set of new pushrods. I have about $3000 worth of pushrods in a drawer, so I reuse pushrods whenever possible! Mopar ones can be cut down to work in most any other engine since RB blocks are so tall.
Re: 521 progress
[Re: AndyF]
#3206276
01/19/24 05:16 PM
01/19/24 05:16 PM
fast68plymouth
So. Burlington, Vt.
197@.200 would be huge for a lobe that’s 267@.050. It would still be quite big for a lobe that’s 273@.050.
Re: 521 progress
#3206355
01/19/24 09:08 PM
01/19/24 09:08 PM
AndyF
Might be close to a HXL lobe. Lobe 2233 is 303 advertised, 274@050 and 197@200 with 454 lobe lift.
The Kaase lobe seems to be a little more aggressive than most of the lobes I could find in the Comp lobe family book. Maybe Kaase is taking advantage of the larger cam journal size that the big Fords have?
Re: 521 progress
[Re: AndyF]
#3206456
01/20/24 11:27 AM
01/20/24 11:27 AM
fast68plymouth
So. Burlington, Vt.
Might be close to a HXL lobe. Lobe 2233 is 303 advertised, 274@050 and 197@200 with 454 lobe lift. Let me quantify my previous statement……… It seems like a pretty quick lobe for a combo using large steel valves, 1.75 rockers, and springs that are only 600lbs open. I’m not going to second guess Kaase, so the proof of concept will be told on the dyno. That being said, I don’t feel like the cam(from what we can tell thus far) and the springs/RR are that well matched. If after a couple of hundred trouble free 1/4 mile passes, and the springs still test good afterward……..then it can be said the combo is well sorted out.
Re: 521 progress
[Re: mopar873]
#3208060
01/25/24 11:47 AM
01/25/24 11:47 AM
gregsdart
Looking good. It is hard to believe what SBC's (and Mopar and Ford) are making recently. There are a handful of SBC builds that have crested 800hp even with 23 degree heads and cast single carb intakes. Some of the best 23 degree stuff is done by Chad Speier. Those flow over 350. When you step up to some of the more recent head designs and improved valve angles, the hp goes up rapidly from there. I love seeing what Guys like Brett, Chad, Bob Book, M@M, Uratchko, etc make for power. It's a whole different level. I agree. A friend runs a gen3 392 hemi, dynos 775 hp with stock class rules heads, stock valvetrain parts,save for cam and springs i believe. Car runs the numbers to back that up.
Re: 521 progress
#3208392
01/26/24 10:21 PM
01/26/24 10:21 PM
AndyF
Andy, what did the RR work out to be with the full spring load? Rocker arm ratio appears to be good. Getting about 0.790 lift with everything bolted up and ready to go. Lash is 0.018 on the exhaust.
Re: 521 progress
[Re: AndyF]
#3208446
01/27/24 10:10 AM
01/27/24 10:10 AM
HardcoreB
Shelby Twp. Mi
The Kaase lobe seems to be a little more aggressive than most of the lobes I could find in the Comp lobe family book. Maybe Kaase is taking advantage of the larger cam journal size that the big Fords have? You're probably right, the variation and listed values probably differ because of various lifter wheel diameters. The HXL lobes have a good reputation with a few people I know.
Re: 521 progress
#3208447
01/27/24 10:12 AM
01/27/24 10:12 AM
HardcoreB
Shelby Twp. Mi
Might be close to a HXL lobe. Lobe 2233 is 303 advertised, 274@050 and 197@200 with 454 lobe lift. Let me quantify my previous statement……… It seems like a pretty quick lobe for a combo using large steel valves, 1.75 rockers, and springs that are only 600lbs open. I’m not going to second guess Kaase, so the proof of concept will be told on the dyno. That being said, I don’t feel like the cam(from what we can tell thus far) and the springs/RR are that well matched. If after a couple of hundred trouble free 1/4 mile passes, and the springs still test good afterward……..then it can be said the combo is well sorted out. Not that it'd matter to anyone but I am consistent with this opinion/well said.
Re: 521 progress
[Re: AndyF]
#3208460
01/27/24 11:23 AM
01/27/24 11:23 AM
fast68plymouth
So. Burlington, Vt.
So that’s .790 net lift after lash?
Or, .790 lift at zero lash?
If it’s after lash, the RR is higher than 1.75
You must be getting close to making some noise.
Re: 521 progress
#3222714
03/25/24 03:35 PM
03/25/24 03:35 PM
AndyF
Sitting on the stand waiting to run on the dyno. I had to fabricate some parts for the vacuum pump system so that took some time. But now it is ready to go, just waiting for a hole in the schedule.
