Re: 521 progress
[Re: AndyF]
#3194141
11/29/23 12:13 PM
11/29/23 12:13 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A few minutes with a spring tester and you should be able to determine if the springs are suitable.
For that application(and what you’re doing with the engine), if you can get close to 2” IH, I’d probably go with something like a PAC-1225.
I haven’t used “tons” of Manley springs…….but more than a few sets. Nothing stands out in my memory with any of them being way out of spec…….but anything is possible.
Re: 521 progress
[Re: AndyF]
#3194170
11/29/23 01:42 PM
11/29/23 01:42 PM
Posts: 16,923 NC
440Jim
NC
I did have this issue before with dual conical springs from Comp. They told me to use the dual conicals for a solid roller cam but the catalog says they are only 150 on the seat. We went ahead and got the dual conical springs and they measured 200 on the seat, plenty on the nose and the coil bind was just right. So the guy was right, the catalog was wrong and the springs worked great in that engine. That is odd that the actual vs catalog are that far off. But since you have the springs, test them for pressure and coil bind height and see if Kaase is right or wrong. I would use 0.060" before coil bind for my calc.
Re: 521 progress
[Re: Blusmbl]
#3194180
11/29/23 02:22 PM
11/29/23 02:22 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
There is no reason a Callies MP cast iron block is $6500 (hey, it's on sale this week for $6000 at Mancini's!).
Oh, there's a reason! Just not a reason anyone here likes or can agree with lol........ Personally I've drooled over the 200 dollar core 460s on marketplace, but feel like I picked my poison decades ago. It was already one level of dumb to do a Hemi, it'd be an entirely different level to change brands.
Rich H.
Esse Quam Videri
Re: 521 progress
[Re: ZIPPY]
#3194196
11/29/23 04:12 PM
11/29/23 04:12 PM
Posts: 31,000 Oregon
AndyF
Oh, there's a reason! Just not a reason anyone here likes or can agree with lol........ Personally I've drooled over the 200 dollar core 460s on marketplace, but feel like I picked my poison decades ago. It was already one level of dumb to do a Hemi, it'd be an entirely different level to change brands. I got divorced, sold my house and shop, moved, got a new shop and bought a new house all in the last 12 months so changing engine brands is not a big deal in the grand scheme of things!
Re: 521 progress
[Re: AndyF]
#3194204
11/29/23 04:29 PM
11/29/23 04:29 PM
ZIPPY
S.E. Michigan
Oh, there's a reason! Just not a reason anyone here likes or can agree with lol........ Personally I've drooled over the 200 dollar core 460s on marketplace, but feel like I picked my poison decades ago. It was already one level of dumb to do a Hemi, it'd be an entirely different level to change brands. I got divorced, sold my house and shop, moved, got a new shop and bought a new house all in the last 12 months so changing engine brands is not a big deal in the grand scheme of things! The desire and the means need to exist first: Neither one does Regardless, glad to hear you were able to move on when you needed to. You've been offloading stuff for quite awhile and have made a few comments here and there about "losing the shop" that seemed too serious to be a parody of reality TV show script.
Rich H.
Esse Quam Videri
Re: 521 progress
[Re: AndyF]
#3205961
01/18/24 04:19 PM
01/18/24 04:19 PM
fast68plymouth
So. Burlington, Vt.
Andy, what did the RR work out to be with the full spring load?
Re: 521 progress
[Re: AndyF]
#3206122
01/19/24 09:30 AM
01/19/24 09:30 AM
Posts: 4,045 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Figured the top end was ready to go together but discovered that the Cometic gaskets that Kaase recommended overhang into the combustion chambers. They said use 4.500 bore gaskets which seemed safe with a 4.390 bore size, but the chambers in the head are so big that the gasket overhangs near the exhaust valve. Evidently Kaase runs it that way but the engine builder I'm working with said to order new gaskets. So I got a set of 4.600 gaskets ordered from Summit.
If I get a chance to do another engine I think I'll buy the 4.500 bore block from Ford and build a 4.500 x 4.500 engine with the same exact heads. Be interesting to see the comparison between the two. The Ford blocks are available for $3900 which seems like an okay price. A few things here just seem ODD with the advice coming out of Kaase. I don't know how many "Ford" people builds there are to gage the success on what seems to be bad direction. But I'd be doing the things you are despite recommendations otherwise. I've seen some of the pieces here and there and appreciate the packages and prices Kaase offers so, I like you are sharing this build. There are engine build things that translate to any platform. I'd be curious to know actual NET lift as well to see where the springs are from c/b. Can you share the entire cam profile to gage its intensity?
Re: 521 progress
[Re: AndyF]
#3206194
01/19/24 01:36 PM
01/19/24 01:36 PM
fast68plymouth
So. Burlington, Vt.
Andy did you plot out the cam at all? Wondering if you had a duration @.200 number.
Re: 521 progress
[Re: 451Mopar]
#3206237
01/19/24 03:20 PM
01/19/24 03:20 PM
HardcoreB
Shelby Twp. Mi
Sounds like the wrong spring for a 0.800" lift cam. 1.950" install height and 1.170" coil bind is only 0.780" lift? Do they want them installed at a higher install height like 2.00"? I wouldn't think so as 235 seat pressure @1.950", and 535 lb/in rate seem fairly low pressures for such a large cam? Reviewing this thread after looking at that cam card I wouldn't run so little a spring even if the valves were titanium. I'd guess it'll float the valves before 6000rpm.
Re: 521 progress
[Re: fast68plymouth]
#3206271
01/19/24 05:05 PM
01/19/24 05:05 PM
AndyF
Andy did you plot out the cam at all? Wondering if you had a duration @.200 number. When I checked the intake lobe I measured 267@050, 197@200 and 90@400. But that was early in the build during a mockup session. Numbers could be slightly off due to a temp setup. Exhaust was 202@200 and 92@400
Re: 521 progress
[Re: HardcoreB]
#3206274
01/19/24 05:11 PM
01/19/24 05:11 PM
AndyF
Sounds like the wrong spring for a 0.800" lift cam. 1.950" install height and 1.170" coil bind is only 0.780" lift? Do they want them installed at a higher install height like 2.00"? I wouldn't think so as 235 seat pressure @1.950", and 535 lb/in rate seem fairly low pressures for such a large cam? Reviewing this thread after looking at that cam card I wouldn't run so little a spring even if the valves were titanium. I'd guess it'll float the valves before 6000rpm. We'll keep an eye on it. I've run those springs before with cams like this and haven't had an issue. I used the same spring in my old 514 dyno mule with 1.80 rocker arms and it pulled past 7000 rpm without any issue. That engine had Jesel rocker arms and 7/16 dual taper pushrods. This engine has T&D rockers and the same pushrods. The pushrods are literally the same ones. I sent them back to Smith Bros and had them cut down and replaced the cup with a ball. Saved me $400 over a set of new pushrods. I have about $3000 worth of pushrods in a drawer, so I reuse pushrods whenever possible! Mopar ones can be cut down to work in most any other engine since RB blocks are so tall.
