1965 aluminum Hemi "K" Heads
#3191161
11/15/23 04:31 PM
11/15/23 04:31 PM
Posts: 1,549 Mattituck NY.
FJ6AAR
Mattituck NY.
Hi all, I am just wondering everybody's opinion on the 1965 "K" Hemi aluminum heads? I am building another engine and came across a real nice set that were never cracked or milled to death. They do have newly installed valve seats - both intake and exhaust. The heads have not been run since the seats were installed. Assuming the seats were installed with the correct interference, what is your opinion of these heads? Are they prone to cracking, or do they have porosity issues, ie. bad castings with pin holes? They will be pressure tested before I build them. Just wondering everybody's opinion on them since there is some good Hemi knowledge here. By the way, the engine will be 9:1 compression with a very mild camshaft - it will be all show without the go. I just want to cruise around town and not race it at all. Thanks, Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: 1965 aluminum Hemi "K" Heads
[Re: A727Tflite]
#3191186
11/15/23 05:24 PM
11/15/23 05:24 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You didn’t ask for my opinion but I would sell those to a guy that needs them for a real 65 car and buy a new set of Eddy’s.
And pocket some money with no worries. Couldn't agree more. Plus a better selection of valve covers.
2011 Drag Pak Challenger
[Re: A727Tflite]
#3191210
11/15/23 07:24 PM
11/15/23 07:24 PM
FJ6AAR
Mattituck NY.
Thank you for the replies everyone. At this point, I plan on using them. I do have the valve covers for them. Although, I guess a nice new pair, or really clean used newer pair of aluminum Mopar heads would be an interesting trade? I didn't realize there are guys out there that specifically look for and use these heads.
[Re: FJ6AAR]
#3191218
11/15/23 07:37 PM
11/15/23 07:37 PM
rickseeman
Stuttgart, Arkansas
What you have is the most valuable hemi head. If they are decent you can swap them for new Edelbrocks or Mopar heads. But Mopars of course won't run with Edelbrock Victor Jrs. And if the valve covers are decent they are worth good money too.
[Re: rickseeman]
#3191238
11/15/23 08:37 PM
11/15/23 08:37 PM
FJ6AAR
Mattituck NY.
What you have is the most valuable hemi head. If they are decent you can swap them for new Edelbrocks or Mopar heads. But Mopars of course won't run with Edelbrock Victor Jrs. And if the valve covers are decent they are worth good money too. Good to know, thanks for the reply. So, I guess the castings are good and there is nothing to worry about as long as they check out.
[Re: FJ6AAR]
#3191274
11/15/23 10:35 PM
11/15/23 10:35 PM
rickseeman
Stuttgart, Arkansas
Nothing at all wrong with the castings. The only problem is they are old. I mean really old. Usually very tired and have been worked over many times. I don't even have a use for them but if they are decent I would ship you new Edelbrocks for the heads and valve covers. I do have to admit I love 65 parts because the 1965 Super Stock Dodge is my favorite car of all time.
[Re: 340Cuda]
#3191357
11/16/23 01:11 PM
11/16/23 01:11 PM
rickseeman
Stuttgart, Arkansas
The first heads that were legal replacements for the 65's were the "replacement heads" aka "twin plug heads" aka "Ross Foundry heads" aka "433 heads". I assume the heads made in the late 90's were also legal. They let people run all kinds of stuff in S/S now.
[Re: rickseeman]
#3191361
11/16/23 01:18 PM
11/16/23 01:18 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
The first heads that were legal replacements for the 65's were the "replacement heads" aka "twin plug heads" aka "Ross Foundry heads" aka "433 heads". I assume the heads made in the late 90's were also legal. They let people run all kinds of stuff in S/S now. You only need to worry about being correct casting numbers or "legal" heads is IF you get torn down after winning a NHRA race or set a NHRA class record NHRA tech has changed a bunch on what is legal in both Stock and super Stock Contact your NHRA division tech department or NHRA tech national to get the straight scoop on what they allow
[Re: FJ6AAR]
#3191373
11/16/23 02:36 PM
11/16/23 02:36 PM
Posts: 1,672 Virginia
HemiStan
Virginia
What you have is the most valuable hemi head. If they are decent you can swap them for new Edelbrocks or Mopar heads. But Mopars of course won't run with Edelbrock Victor Jrs. And if the valve covers are decent they are worth good money too. Good to know, thanks for the reply. So, I guess the castings are good and there is nothing to worry about as long as they check out. You have heads and valve covers. But do you have valve cover gaskets??…. They are specific to those heads and I do not believe they are being reproduced. Stan
[Re: 340Cuda]
#3191388
11/16/23 04:33 PM
11/16/23 04:33 PM
Posts: 3,087 Michigan
A727Tflite
Are the "1965 "K" Hemi aluminum heads" the only ones NHRA allows on 65 Stock and Super Stock cars or is there a aftermarket replacement allowed? Go to NHRARacer.com. It’s the location for class weights, factors and engine blueprint specs. It will tell you what part numbers are allowed for heads, manifolds, carbs, etc., amongst other things important if you race NHRA.
[Re: FJ6AAR]
#3191390
11/16/23 04:41 PM
11/16/23 04:41 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
Selling them and getting Eddies is probably a good idea. Those will be worth big $$$$ to the right guy. We found in the old days they had a tendency to crack around the valve seats, probably because the metalurgy in 1965 was not what it is today. They take a unique valve cover, too, and even gaskets can be hard to ffind and someone will hold you hostage to get them.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: HemiStan]
#3191484
11/16/23 09:39 PM
11/16/23 09:39 PM
FJ6AAR
Mattituck NY.
What you have is the most valuable hemi head. If they are decent you can swap them for new Edelbrocks or Mopar heads. But Mopars of course won't run with Edelbrock Victor Jrs. And if the valve covers are decent they are worth good money too. Good to know, thanks for the reply. So, I guess the castings are good and there is nothing to worry about as long as they check out. You have heads and valve covers. But do you have valve cover gaskets??…. They are specific to those heads and I do not believe they are being reproduced. Stan As luck would have it, there is a set on Ebay now. But I can easily make my own out of gasket material, have done it before but not for the K heads. https://www.ebay.com/itm/295805039929?
[Re: FJ6AAR]
#3191582
11/17/23 11:54 AM
11/17/23 11:54 AM
rickseeman
Stuttgart, Arkansas
What you have is the most valuable hemi head. If they are decent you can swap them for new Edelbrocks or Mopar heads. But Mopars of course won't run with Edelbrock Victor Jrs. And if the valve covers are decent they are worth good money too. Good to know, thanks for the reply. So, I guess the castings are good and there is nothing to worry about as long as they check out. You have heads and valve covers. But do you have valve cover gaskets??…. They are specific to those heads and I do not believe they are being reproduced. Stan As luck would have it, there is a set on Ebay now. But I can easily make my own out of gasket material, have done it before but not for the K heads. https://www.ebay.com/itm/295805039929? I wouldn't try to make cork gaskets. You can find some eventually for a little less than $100. Fel Pro MS90007 intake gaskets have crossram gaskets included. That guy is always a little bit high but I'm glad he's out there supporting 65's.
[Re: 340Cuda]
#3192492
11/21/23 06:46 PM
11/21/23 06:46 PM
Posts: 3,505 DFW
mr_340
DFW
Are the "1965 "K" Hemi aluminum heads" the only ones NHRA allows on 65 Stock and Super Stock cars or is there a aftermarket replacement allowed? For the 1964 Hemi engines, NHRA lists this: A -2468016 OEM CI Head uses S/SS Factors A -2780559,2780559-M,2780559-M1,2780559-M2 CI Heads use S/SS Factors A -2531110,2531110-M,2531110-M2,3614433 AL Heads use S/SS factor with replacement heads For the 1965: A -2531110 OEM AL Head uses S/SS Factors A -2780559,2780559-M,2780559-M1,2780559-M2 CI Heads use S/SS Factors A -2531110-M,2531110-M2,3614433 AL Heads use S/SS factor The 433 heads are legal with one plug blocked in each cylinder since it was a dual plug head.
Floyd Lippencott IV
[Re: rickseeman]
#3196578
12/10/23 09:32 PM
12/10/23 09:32 PM
FJ6AAR
Mattituck NY.
I bought two of the three sets available in this auction. I see now the third set is sold too.
