Re: 73 Plymouth RR clone Best Sway bar for cornering?
[Re: ThermoQuad]
#3191895
11/18/23 08:44 PM
11/18/23 08:44 PM
Posts: 22,696 Bitopia
jcc
Bitopia
How much money are you willing to spend? Nothing, but until OP states he is now interested in improving "handling" rather than his initially stated request of "corner", which is usually measured on a skid pad and/or with g meter, I'll enjoy my popcorn pretty far away from the turd tossing.
[Re: jcc]
#3192179
11/20/23 11:43 AM
11/20/23 11:43 AM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
The pissing matches in this post are nuts. Bloke asked a simple question.
I've done all this to an M body in increments and can give you a fairly good cost/benefit breakdown.
Assuming you already have modern radial tires on the car, as suggested first thing to do is eliminate the ISO biscuits. Firm Feel sells the blocks you'll need to do this for the front end. You can probably skip over eliminating the rear, but I wouldn't. Convert it to an earlier B body solid shock plate setup. Get the front and rear bars from Firm Feel. The difference in handling at this point will be astronomical. Ride quality won't take that much of a hit.
From here you can decide if you want toss money at taking it further.
If your car doesn't have frame ties in it yet this would be the next thing to do. It'll make another huge improvement in handling and overall feel to the car.
Past this point you're looking at expensive shocks and different torsion bars and would warrant an entirely new conversation.
Good luck.
[Re: MarkZ]
#3192230
11/20/23 04:13 PM
11/20/23 04:13 PM
jcc
Bitopia
The pissing matches in this post are nuts. Bloke asked a simple question This one? " Hey does anyone still make Sway bars to get these old boats to corner?" Simple answer for those with ADD that has already been answered, NO
