https://www.facebook.com/marketplace/item/1325026301721326/Pic of this weird thing in case the image doesn't display[img]
https://scontent-ord5-2.xx.fbcdn.ne...x7BnbWYAnQeV89NYbtl1ZqbA&oe=65485CAA[/img]
1991 Ford F150 custom ramp truck articulating
Mileage- 35,200
Title- Clean
Transmission- Standard 5 speed manual-new clutch
Engine type- 300 6 cylinder
Fuel- Gas
Brand new windshield!
This 1991 F150 was a purpose built truck, not so much for recovery along open roads but for the use in big city's; with all those parking ramps, and narrow roads. It's quite difficult removing cars from those structures, and that is exactly what this one of kind truck was designed to do. This truck was a prototype and the only one manufactured. It was built to fit almost any small to medium size car or SUV. It won't work on tall pickup trucks or vans ect.
This truck articulates just behind the cab approximately 25°-30° degrees to either the right or the left. Hence the round shape of the bed.
It has an extreme low load angle for
clearance, which also helps with ground effects, and low bumpers on modern cars. As well as total overhead clearance in parking garages.
All functions are controlled with a wireless loadar radio controlled key pad.
This truck is highly maneuverable in tight spots, and easy to align with parked cars in ramps. It has a self centering ramp\ floor to eliminate body damage when loading and unloading. The ride height on tail board is approx 12" in from ground.
This custom built 1991 F150 is truly unique, and is worth a look. If you do this type of work in big city's this truck is made for you. If you have questions or would like to come see it in person please feel to reach out. I'm selling this for my boss and he will be able to answer any thing you might need to know.
Front wheels in rear are limited slip. Rear wheels are floaters, and cab (front) wheels don't drive.
We still have all receipts and paperwork for the custom fabrication that it took to make this a one of kind truck. Please reach out via a phone call
