Timing set for raised cam Hemi?
#3188045
11/01/23 01:46 PM
11/01/23 01:46 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Other than a belt, what are the available options for a timing set on a raised cam KB block block?
I know that big block Chevy's have the same cam to crank center line as a big block Mopar. Is there a bbc raised cam timing chain that could be used with Hemi sprockets? Is a gear drive available?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Timing set for raised cam Hemi?
[Re: rickraw]
#3188108
11/01/23 06:19 PM
11/01/23 06:19 PM
Hemi_Joel
Minnesota
[Re: Hemi_Joel]
#3188121
11/01/23 06:58 PM
11/01/23 06:58 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
Plenty of gear drives available...not so sure about a chain.sprocket set up though.. Id try Wizards first.. This is where I do most my gett'n stuff at. Tell'em Bill in NY sent you! RBS sells them Too
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: rickseeman]
#3188260
11/02/23 12:32 PM
11/02/23 12:32 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Have always had good luck with RCD even with BBC stuff.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3188266
11/02/23 12:49 PM
11/02/23 12:49 PM
Posts: 10,045 MN
JERICOGTX
MN
Did you order a block Joel?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3188321
11/02/23 05:33 PM
11/02/23 05:33 PM
Hemi_Joel
Minnesota
No, I'm still on the fence.
[Re: quickd100]
#3188646
11/03/23 11:19 PM
11/03/23 11:19 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I believe using the belt that this gets rid of all the bad harmonics throught the Chain and Sprockets. I believe the belt is a common thing in performance motors, but the price years ago with the raised block was not that cheap. I would phone Banning or Barton and talk to them on what other timing Chain, Drive they recommend.
1971 HEMI E BODY REGISTRY
[Re: sasquatch]
#3188874
11/05/23 11:06 AM
11/05/23 11:06 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
I am sure you could even make a stock stlye cover fit, might take a spacer if sorts but why not.
[Re: hemicar1971]
#3188904
11/05/23 12:34 PM
11/05/23 12:34 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I believe the belt is a common thing in performance motors, but the price years ago with the raised block was not that cheap. They are worse now. Over $2,000 including tax. I've bought hemicudas cheaper.
2011 Drag Pak Challenger
[Re: sasquatch]
#3189058
11/06/23 06:58 AM
11/06/23 06:58 AM
Posts: 10,045 MN
JERICOGTX
MN
Joel Just thinking out loud here. I wonder if the Indy timing cover would cover the belt drive. Ati makes the damper for it. Full disclosure Joel and I have been discussing this. His concern with a belt drive is he wants to do Drag week and Belt drives can pick up all sorts of things flying down the open road. I pulled a large stone out of one the other day! So maybe we could cover it up.......Let me look into this. Todd The odds of it happening are very slim... Plenty of people running belts on Drag and Drive events without issues. I do have a INDY cover if Joel wants to look at it. NO Joel, you can't use it... LOL.
69 GTX
68 Road Runner
[Re: Al_Alguire]
#3189104
11/06/23 01:35 PM
11/06/23 01:35 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I am sure you could even make a stock stlye cover fit, might take a spacer if sorts but why not. I started to cobble up a stock timing cover to put over a jesel years ago , never finished it and ended up selling the jesel. I started by cutting the bottom flange off , left out the balancer seal.
[Re: JohnRR]
#3189149
11/06/23 04:10 PM
11/06/23 04:10 PM
Hemi_Joel
Minnesota
I suppose anything is possible...
[Re: '72CudaRacer]
#3189972
11/09/23 11:15 PM
11/09/23 11:15 PM
hemicar1971
Chicago Blackhawks
Have not talked to Banning about this for a long while but the old research for using a Chain and Sprockets states that there are none and likely will never be any for this raise came block, unless someone does a lot of research into building one. Talked to a couple of racers that have the belts and have no problem with them. Was told that Oil is a killer of the belts. These belt assemblies are not cheap but do add some benifits to the motors.
[Re: hemicar1971]
#3190029
11/10/23 11:55 AM
11/10/23 11:55 AM
rickseeman
Stuttgart, Arkansas
Banning has a raised cam belt drive listed on his website. I assume it's the one made by the Aussies. Just speculation.
