'65 Valiant 4dr w/warmed up /6; $7,200
#3186591
10/26/23 09:37 AM
10/26/23 09:37 AM
Posts: 12,073 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This 65 Plymouth Valiant V200, is not your grandmother's car! This iconic leaning tower of power has been worked over and rebuilt completely. This is a very solid car with no much rust. Floors are soild, as well as the trunk. New parts include- Holley EFI in-tank electric fuel pump FiTech Go Street 400 EFI throttle body injection Aussiespeed Hurricane 4 bbl intake Clifford headers (exhaust needs to be finished but have all the stainless 2.25in pipe to finish) Crankshaft has been polished Brand new .060 over flat top pistons Shaved .075 off the head to bump compression Hardened valve seals Comp Cams 215/215 solid flat cam Valve springs, lifters, valves, and pushrods High flow oil pump Oil pickup tube Thermostat Alternator Waterpump HEI ignition MSD high output coil AGM batterywww.facebook.com/marketplace/item/295894630050501
Master, again and still
