Re: Hemi, power brakes, and the #7 spark plug
[Re: 360view]
#3182934
10/10/23 10:59 PM
10/10/23 10:59 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Back when I had my '71 Hemi Charger R/T, I had very little problem doing that plug - I'd put fresh plugs in every spring. PDB car. Different models & years MUST have had different clearances, because mine was not that difficult.
Now I had a buddy with a 1969 Mach 1 with a 390 & there was at least one plug where you had to jack the engine up several inches to get at one of the plugs. That would get old real fast! That engine was shoehorned in.
[Re: Sunroofcuda]
#3183046
10/11/23 12:39 PM
10/11/23 12:39 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I converted mine from power disc brakes to manual on this last build. I can do all 8 plugs in less than 5 minutes now. I even have a special one piece T Handle wrench with a built in torque wrench clicker that I use. (Same as the top fuel teams use).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Sunroofcuda]
#3183091
10/11/23 02:03 PM
10/11/23 02:03 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
Now I had a buddy with a 1969 Mach 1 with a 390 & there was at least one plug where you had to jack the engine up several inches to get at one of the plugs. That would get old real fast! That engine was shoehorned in. I used to have a 67 cougar. 390. And yes....spark plus were a nightmare . Especially drivers side
[Re: gtx6970]
#3183248
10/11/23 10:59 PM
10/11/23 10:59 PM
Posts: 3,811 Arlington, Texas
bobby66
Arlington, Texas
Now I had a buddy with a 1969 Mach 1 with a 390 & there was at least one plug where you had to jack the engine up several inches to get at one of the plugs. That would get old real fast! That engine was shoehorned in. I used to have a 67 cougar. 390. And yes....spark plus were a nightmare . Especially drivers side I had a '67 XR-7 GT with the 390. Sweet car but very tight engine compartment.
