Which shocks for 63 b body w/ SS springs #3181689
10/06/23 01:17 PM
10/06/23 01:17 PM
Ohio
O
Old buddy Offline OP
O
Ohio
I have a 63 Polara that I'm installing 3400lb Super Stock springs in. Which rear shocks should I use?
Re: Which shocks for 63 b body w/ SS springs [Re: Old buddy] #3181721
10/06/23 03:30 PM
10/06/23 03:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Buy as much shock as you can afford.
That said, we started with the Calvert 9 position single adjustable on our '63 330. They are fine for a car well into the 10's.
We've been 1.36 60 ft. with them.
I bought Viking Crusaders a while back but just haven't gotten the chance to use them much.
As an aside, the modern made in Mexico SS springs do NOT work well for very long. Granted, I ran ours pretty hard in the first year, but they started losing arch and were done by the end of the season! This is in a drag race application. Part #'s 456/457 which is what I believe you have.
'63 Dodge 330
11.19 @ 121 mph
Re: Which shocks for 63 b body w/ SS springs [Re: Old buddy] #3181851
10/07/23 08:27 AM
10/07/23 08:27 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
This is the handling forum. If a drag application you might find more informative responses it seems in the Race forum.
If indeed a handling question, use a 22" front segment leaf if possible, and upgrade to a fiberglass leaf in whatever spring rate you chose, and save 50?lbs, use a double adjustable shock, like a QA1.
Anything but a KYB. eyes
Re: Which shocks for 63 b body w/ SS springs [Re: Old buddy] #3182931
10/10/23 10:50 PM
10/10/23 10:50 PM
AndyF Offline
AndyF  Offline
Depends on what you are using the car for. For drag racing buy a really high quality drag race shock. For street driving buy the best shock you can afford. I use Koni shocks on my '65 Coronet with SS springs.
Re: Which shocks for 63 b body w/ SS springs [Re: AndyF] #3183161
10/11/23 05:44 PM
10/11/23 05:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For SS springs - whichever shock you use - they need to be taller than stock.
IIRC, '69-'70 Imperials used the length you'll need, and supposedly D100 fronts also work.
It's a good idea to take a measurement at full droop and at max compression.
You don't want the shocks to limit travel.
Also, in my case, the pinion snubber wasn't needed.
