4160 Modification #317886
05/14/09 12:04 PM
05/14/09 12:04 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
How hard is it to switch over from a secondary plate setup to a normal 4150 style metering block secondary on a 4160? What is needed? I want to get a bit more out of the carb when the secondaries open.
I have a 750 I am working on for racing/performance runs, but want to sort this one out as well.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: 4160 Modification [Re: MoparJ] #317887
05/14/09 12:55 PM
05/14/09 12:55 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
quick fuel and holley both make kits to convert from metering plate to metering block.
the kit includes the metering block..longer screws and gaskets.
http://www.jegs.com/i/Quick+Fuel/793/34-66/10002/-1
Tony
70 AARCuda Vitamin C
