DOT Drag Radials on and LB Crossmember Broken #317842
05/14/09 11:08 AM
05/14/09 11:08 AM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
got the new hoosier DOT drag radials on and went for a test drive
after pulling in garage noticed RR tire jammed into rear of qtr panel
upon further investigation found right side LB bracket ripped away from LB crossmember
weld good but metal torn just above weld
any body ever see this before?
WAXER
Re: DOT Drag Radials on and LB Crossmember Broken [Re: QWK_ENUF] #317843
05/14/09 11:43 AM
05/14/09 11:43 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
right beside the weld is a fairly common failure mode. I'll let some of the chassis builders/welders explain why it happened and how to prevent it.
your lucky the rear end stayed under the car. I've seen a few that didn't.
Re: DOT Drag Radials on and LB Crossmember Broken [Re: GomangoCuda] #317844
05/14/09 12:15 PM
05/14/09 12:15 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
i'm thinking side to side flex . this has been in the car over 6 years
other opinions wanted
WAXER
