Re: 360 Block?
[Re: emarine01]
#316919
05/13/09 11:44 AM
05/13/09 11:44 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Nothing is a given. The 71 blocks seem to have the aura of being thicker. But core shift tends to make that a myth. If you plan to go 4" stroke, have it sonic tested. Look for a minimum of .150" (or whatever your builder likes to see) on the major thrust and go from there. I dont like to do strokers bored further than .030 unless the block tests perfect. For stock stroke, I think .040 is the max recommended overbore. Again, sonic test to be sure if you want more.
