71 Cuda Booster rod to master piston clearance #3168773
08/18/23 11:48 AM
08/18/23 11:48 AM
Metro Detroit,Michigan
I
isettakurt Offline OP
I
Hello,
I have a 71 'cuda power disk brakes with a Midland Ross direct mount booster. What is the clearance for the booster rod to master cylinder piston. Thanks
Re: 71 Cuda Booster rod to master piston clearance [Re: isettakurt] #3168814
08/18/23 01:54 PM
08/18/23 01:54 PM
moparx Offline
moparx  Offline
i believe it's around .020-.030
beer
Re: 71 Cuda Booster rod to master piston clearance [Re: moparx] #3169773
08/22/23 07:11 PM
08/22/23 07:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
beer
For a GM product that would be the norm, but Chrysler's seem to work well with .060 (1/16 inch) clearance......
Re: 71 Cuda Booster rod to master piston clearance [Re: DAYCLONA] #3169905
08/23/23 01:44 PM
08/23/23 01:44 PM
moparx Offline
moparx  Offline
beer
thanks for the clarification. up bow
after flipping through a couple of FSM's, all i could find was the booster rod length from the master cylinder mounting surface at the booster to be .910-.920. there was no mention of clearance between the booster rod and the master cylinder piston bore depth.
not having a master cylinder handy to measure the piston bore, i didn't have a reference.
beer
Re: 71 Cuda Booster rod to master piston clearance [Re: moparx] #3169938
08/23/23 03:59 PM
08/23/23 03:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wouldn't that be figured into the length?
Re: 71 Cuda Booster rod to master piston clearance [Re: stumpy] #3169944
08/23/23 04:20 PM
08/23/23 04:20 PM
moparx Offline
moparx  Offline
i would assume [everyone knows what that word REALLY means biggrin] so.
but not having a master here to measure the piston bore depth, [in my machinist tools, i have a "round bottom" stem set for my depth mics] i can't come up with the clearance that booster measurement would create in the master cylinder piston bore.
beer
Re: 71 Cuda Booster rod to master piston clearance [Re: moparx] #3169978
08/23/23 07:37 PM
08/23/23 07:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I made mine as they weren't so cheap and available years ago LINKY As for the clearance question,.030 should be adequate .060 IMO is a little to much but better to have enough than not enough. Do keep in mind more clearance leads to more pedal travel before braking begins. How much? depends on a number of variables. I usually shoot for .030 - .040" and call it good. twocents beer
