Re: Fuel Filter Replacement
[Re: JohnRR]
#3168077
08/15/23 01:10 PM
08/15/23 01:10 PM
Posts: 19,591 north of coder
moparx
if the filter hose is looking bad on the outside, imagine what is happening inside........ the filter is more than likely filling up with fuel hose tidbits. change it. they are cheap enough......
[Re: gtx6970]
#3168113
08/15/23 03:05 PM
08/15/23 03:05 PM
Posts: 5,345 Planet Earth
RoadRunnerLuva
Planet Earth
Since you are changing the hose, which you can see is gone bad, the filter (after 15 years) is bad as well. Might as well do it all the same time.
Plymouth Makes It!
