Re: Labor rate for working on Mopars? [Re: PhillyRag] #3166723
08/09/23 06:55 AM
08/09/23 06:55 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
No Good deed goes unpunished.
but also:
Feel the fear and do right anyways.
Re: Labor rate for working on Mopars? [Re: TJP] #3166733
08/09/23 07:58 AM
08/09/23 07:58 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Originally Posted by TJP
Easy 7-10K IMO with parts. Or take it somewhere else. Do keep in mind if it comes back for a problem you may have to eat it twocents
x2. Jeff, the quality of work you do is as good or better than any shop I've seen and the rate should match accordingly.
I had a bit of a wakeup call when I needed the alignment on the Fury before Sick Summer. It turned into alignment + new lower balljoints, new LCA bushings + finding, restoring and installing a new driver's side LCA to replace the cracked one, and paying for overnight shipping from Canada. That work alone was almost $2000, between parts and their shop rate of $75/hr.
Re: Labor rate for working on Mopars? [Re: JERICOGTX] #3166742
08/09/23 08:32 AM
08/09/23 08:32 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
Originally Posted by JERICOGTX
I'm curious for those that work on other peoples Mopars, roughly what do you charge them for labor rates? Most of the stuff I work on is my own, my immediate family, or close personal friends. lately I've been working on a 69 Charger. Was a complete running car when it arrived. Original 383 2 Bbl car. Here is a list of the things I've done to it:
R&R 906 heads with 440 Stealth heads.
R&R the original single exhaust, with TTi headers, and exhaust
Rebuilt the front suspension
Installed disk brakes
New master cylinder
Removed oil pan, and transmission pan, cleaned and reinstalled for leaks
Installed electronic ignition
Stripped, cleaned, painted original valve covers
Installed Performer RPM intake
Installed Edelbrock carburetor
Install new starter
Remove interior, install new carpet, reinstall interior
Install new washer bottle
I have a bunch of time into cleaning all the parts, and painting stuff. EVERYTHING was super greasy. Pretty sure the original short block has never been out of the car.
I just want to see if my bill to the customer is in line with others.
Thanks.
Jeff
$150 an hour or they can take that garbage elsewhere.. like stated ealier if the owner has any little issue it will be back and you may need to eat that time.. you need to be paid for the headache of doing the work and the potential headache after the work.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Labor rate for working on Mopars? [Re: MOPARMIKE69] #3166766
08/09/23 10:32 AM
08/09/23 10:32 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by MOPARMIKE69
Close friends small job no charge just bring drinks.
Club member with larger project $25 per hour.
Non club member more involved project $50.00 and hour
Thats all for mechanical and restoration work.
Paint and body I charge buy the job client buys all paint and materials. I start at $10,000. and go from there.
Sounds good to me.
Friends we swap labor. Family is for the most part free, just pay for parts.
Anyone else , $$$$$ Depends on the job itself if I really want to do it, or not.
Re: Labor rate for working on Mopars? [Re: gtx6970] #3166779
08/09/23 11:10 AM
08/09/23 11:10 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I typically don't do work unless I know the person and charge half the current rate.
Weirdo cars I charge full labor rate.I have one guy who has a Renault Turbo2 and has to trailer it up to NY to be worked on unless I will.
Re: Labor rate for working on Mopars? [Re: RTSE4ME] #3166856
08/09/23 03:28 PM
08/09/23 03:28 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would not have touched it until the owner and myself had an understanding of the amount of money involved. Hourly rate would have been discussed before it came into my shop. Then payments would have been on a regular schedule (weekly or monthly) as the process moved forward, (work time documented as to start and stop times, need it in writing should it ever have to go to court) and parts cost (including search time, profit margin, taxes, and shipping to my door) would have been covered before the parts were ordered. The 2 or 3 big projects I did were all done this way, and the customer was required to stop in every 2 weeks so everyone knew what was being accomplished, and any changes that might need to be done could be discussed. There were also time limitations and storage procedures outlined, should the work have to be postponed by either party for any reason. This system worked well.
There was a guy in our town that had a reputation of screwing nearly everyone he did business with. I knew him personally. When we started doing business we set up this process. When he wanted to start skipping steps I told him we were done doing business. I was one of very few businesses the guy didn't screw.
Seen way too many guys get burned any other way.
Asking these questions at this point, are pretty late in the game. I hope it works out for you.
Re: Labor rate for working on Mopars? [Re: poorboy] #3166888
08/09/23 06:18 PM
08/09/23 06:18 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I have stopped bringing in cars for side work. I'll do parts jobs. The problem with cars is, even one that looks nice, ALWAYS turns into project creep and has issues with things that were not done well. I don't have time to waste on other people's junk.
Re: Labor rate for working on Mopars? [Re: Jim_Lusk] #3166979
08/10/23 06:07 AM
08/10/23 06:07 AM
MN
JERICOGTX Offline OP
MN
Thanks for the replies everyone. Labor rates were loosely discussed when the project was started. The Charger is owned by my Cousin. He has been great to deal with. I told him what to buy, it's ordered, and on my door step in a few days, no questions asked. He's never once pressured me to get the car done. I gave him the bill yesterday, and he was more than happy with the price.
I test drove the car last night, and it still needs a few tweaks. Mainly getting the Edelbrock carb sorted out.
69 GTX 68 Road Runner
Re: Labor rate for working on Mopars? [Re: JERICOGTX] #3166983
08/10/23 06:53 AM
08/10/23 06:53 AM
tboomer Online work
tboomer  Online Work
Looks nice Jeff! Want me to send ya a pic of what I am buying? wave
Re: Labor rate for working on Mopars? [Re: tboomer] #3166987
08/10/23 07:16 AM
08/10/23 07:16 AM
MN
MN
I saw your post. Send me the picture. Don't send me the car to work on. LOL!
Re: Labor rate for working on Mopars? [Re: JERICOGTX] #3166991
08/10/23 07:35 AM
08/10/23 07:35 AM
tboomer Online work
tboomer  Online Work
Ok! You're not an a body guy or a small block guy or a fluid couple guy!! Lol!! At least I can drive this one and I will always have fond memories of my 64... up
