Source for the latch bolts for a 1991 full size tailgate? #3160601
07/18/23 02:24 PM
07/18/23 02:24 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Hello all,
My '91 W-350 came to me with a high top canopy. I did get the original tailgate with it & the lower pivots are still in place.
I found the folding support arms at Carlisle, but I still need the two top screw in latch anchors for the bedside tops.
Anyone know a source for these?
Thanks!
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: Alaskan_TA] #3160755
07/18/23 09:38 PM
07/18/23 09:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Are you sure they screw in? As I recall they were made onto the panel and not serviceable. Just like the tailgate ones.
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: NITROUSN] #3160836
07/19/23 06:59 AM
07/19/23 06:59 AM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
There are threaded holes where they were removed & can be removed / installed with a Torx bit.
Very similar to a door striker bolt on A, B, C & E-bodies.
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: Alaskan_TA] #3160876
07/19/23 10:02 AM
07/19/23 10:02 AM
N
NITROUSN Offline
NITROUSN  Offline
N
My bad. I was thinking you needed the ones for the check arms. Maybe try to get the part numbers and see were that leads. Otherwise junk yard.
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: Alaskan_TA] #3160882
07/19/23 10:10 AM
07/19/23 10:10 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Used ones. Striker
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: NITROUSN] #3160918
07/19/23 11:38 AM
07/19/23 11:38 AM
moparx Offline
moparx  Offline
Barry, pm me. i "might" be able to get you a pair.
how far back do these bolts interchange ? possibly earlier than 1981 ?
beer
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: moparx] #3160926
07/19/23 11:50 AM
07/19/23 11:50 AM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
No.
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: Alaskan_TA] #3161150
07/19/23 08:23 PM
07/19/23 08:23 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
NAPA? shruggy
Re: Source for the latch bolts for a 1991 full size tailgate? [Re: Hugh Jorgan] #3164355
07/30/23 05:43 PM
07/30/23 05:43 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I finally found a good used set. beer
The canopy on the truck had a door frame that took up the entire width of the tailgate opening, so the installer cut off the T head welded in studs the tailgate arms slip over. shock
I pulled two used brass toilet flange bolts out of the scrap pile, drilled & tapped the cutoff welds & they will work until I can find a better, stronger, permanent solution.
