Page 4 of 4 1 2 3 4
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31627
11/10/12 12:37 AM
11/10/12 12:37 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
My old '71 Hemi Charger R/T w/3:55 gears used to get around 12 MPG in the city, & about 15 on the highway. Car was all stock except for the heads being redone back in the later 70's - a place in Detroit called "Corky's" did them. I was the second owner of the car & bought it in 1980. Lost it in a fire in Aug, 1984. RIP old friend. And yes, oddly enough I did regularly check the fuel mileage just out of curiosity.
Re: 426 hemi mpg what are you getting in yours [Re: Sunroofcuda] #31628
11/10/12 09:59 AM
11/10/12 09:59 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
WOW... Just... wow.
There are some staggering figures in here. I'm going to assume that with all the money usually spent on a hemi that these are generally well-tuned engines too, not just off-the-lot factory engines tuned by the local Dodge tech every month.
Why are they so damn thirsty then? I see lots ov single carb (non Dominator) hemis in here too... still thirsty. Is this a sign ov a generally inefficient engine design? I'm sure Hemi's are fun, and its hard to stay off them, but its not like the 440 guys in here are driving like grannies...
Re: 426 hemi mpg what are you getting in yours [Re: Pale_Roader] #31629
11/10/12 10:32 AM
11/10/12 10:32 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
In 09 I drove my 69 Sat from Houston to Detroit and back for Woodward. It has a 528 Hemi/TF/3.54 Dana. Then, it had the MP crossram, twin Holley 770's and a 266@50/650 solid cam. Running 65 all the way up and back with the A/C on, it got between 8-11 mpg. With a Dynamic 3600 stall converter, I always wondered how much a tighter converter would have helped.
Re: 426 hemi mpg what are you getting in yours [Re: Lee446] #31630
11/10/12 07:22 PM
11/10/12 07:22 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I consider 8mpg pretty decent. The cam is a solid roller .767/.676, 288/292@.050. Tunnel ram with 2 850 thermoquads, 4.56 gears with 31" tires. I've had a 6000 stall 8" convertor and a 10" 4000 stall in it. The mileage was the same, (I did have to drive it real nice though).Dave
Re: 426 hemi mpg what are you getting in yours [Re: HEMIDOG 70] #31631
11/10/12 08:36 PM
11/10/12 08:36 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
about 7/8 city 10 hwy with carb. Now 10 city, 14 hwy with EZ EFI (727 auto trans)
Re: 426 hemi mpg what are you getting in yours [Re: Pale_Roader] #31632
11/10/12 09:49 PM
11/10/12 09:49 PM
central P.A.
HEMIDOG 70 Online content
HEMIDOG 70  Online Content
central P.A.
Hemis are actually a very efficient design. They have very large valves 2.25 intake etc. In my case it's 500 plus cubes a pretty large solid cam and a heavy right foot My 87 4x4 250 Power Ram only got 8.5 mpg it was a 360 with a Qjet 4bbl and 4.10 gears.
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31633
11/11/12 03:15 AM
11/11/12 03:15 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I calculated mine at "I don't care"
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: 426 hemi mpg what are you getting in yours [Re: Lee446] #31634
11/11/12 09:23 AM
11/11/12 09:23 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I drove 114 miles last weekend to a car show. The route was stop and go and about half freeway. My setup is a 540ci HEMI with (2) 750 Hollys on a Stage V intake. The cam is 248/254 @ .050 solid roller. Compression is 10.8. The 727 has a 3500 converter and the Dana has 3.54 gears. The car averaged 10.8 mpg. When I first started driving it the mileage was 7-8 mpg. I tuned the carbs with a vacume gauge and hooded up/tuned the vacume advance in the MP distributor to get the 10.8 mpg. I don't think that is too bad for a 4000lb car and a 540 ci engine spinning 2800-3000 rpm on the freeway.
Page 4 of 4 1 2 3 4
