Page 3 of 4 1 2 3 4
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31607
10/15/08 09:06 PM
10/15/08 09:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
4.26 MPG in town,
5.72 on the highway, Who cares???? LMAO
Not trying to slam you but just inject a bit of humor
Re: 426 hemi mpg what are you getting in yours [Re: TJP] #31608
11/23/10 04:06 PM
11/23/10 04:06 PM
Costa Mesa, California
michaelphbarnett Offline
4.26 MPG in town,
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31609
11/23/10 05:11 PM
11/23/10 05:11 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Back in the era when I used to have my '71 Hemi Charger (1980-84), mine would always get around 12 MPG around town, & 16 on the highway. That car ran like a swiss watch!
Re: 426 hemi mpg what are you getting in yours [Re: Sunroofcuda] #31610
11/23/10 06:00 PM
11/23/10 06:00 PM
QLD Australia
Keith Black® Offline
QLD Australia
at full power will empty a tank in approx 3 minutes.
we should be measuring fuel consumption by seconds or minutes not mpg
Darren Beale
Keith Black Racing Engines®
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31611
11/23/10 07:41 PM
11/23/10 07:41 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I have just under 225 miles on the car so far. I didnt build it for fuel economy, but I thought it would be better than what it is. I am getting between 7-8 mpg out of the car so far. How you others doing with yours.
my set up is
426 siamese block
10.25 to 1 j and e piston
manely rods
eagle crank
426-2 indy intake
850 mighty demon
comp cams 508/519 235 at 50 mechanical cam
msd
2 1/8 hooker super comps
3 inch flowmaster exhaust
bowl and pocket work on the mopar aluminum heads
dana 60 with 3.54
4 speed
29.5x15.5x15 rear tire
2850-3000 rpm's at 70 mph
car weighs in at 3640 with a 1/2 tank
What do you think and how are yours doing. This is still a lot better than my max wedge was doing.
Just over 200 miles from a tank. somewhere around 14.6mpg (Imperial gallons=15.75 Imperial gallons to a tank)
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31612
11/23/10 09:33 PM
11/23/10 09:33 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
We averaged between 10 and 11 on the road. 572 hemi with a 3.73 rear gear.
Re: 426 hemi mpg what are you getting in yours [Re: CRE2004] #31613
11/23/10 10:06 PM
11/23/10 10:06 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
about 10 on the highway with 3.91 and an auto. HP and tq below 9.1 compression
Re: 426 hemi mpg what are you getting in yours [Re: Slipknot440] #31614
11/23/10 11:07 PM
11/23/10 11:07 PM
New Mexico
rr74cuda Offline
rr74cuda  Offline
New Mexico
Mine gets great gas mileage from me pushing it around on the stand. Dont know how many calories an hour though and I seem to produce less torque than I use to. Of course the engine is a 66 and I am a 60 model
Re: 426 hemi mpg what are you getting in yours [Re: rr74cuda] #31615
11/24/10 01:19 PM
11/24/10 01:19 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I get 13.9 MPG with my 572 EFI HEMI.
But I had to do some special EFI tuning to do it.
Running very lean at low load conditions.
Lots of spark advance at low loads.
Shut off all the injectors on an decel.
Hold back on the acell fuel (pump shot) unless you mean it.
I run 91 octane, push button 727 trans and 3.70 rear gear.
Re: 426 hemi mpg what are you getting in yours [Re: rr74cuda] #31616
11/24/10 02:27 PM
11/24/10 02:27 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Re: 426 hemi mpg what are you getting in yours [Re: Mopar_Rich] #31617
11/24/10 02:28 PM
11/24/10 02:28 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
show off
Re: 426 hemi mpg what are you getting in yours [Re: torkrules] #31618
11/24/10 03:29 PM
11/24/10 03:29 PM
PNW
Beebuzzn Offline
Beebuzzn  Offline
PNW
My old 67 Hemi R/T 4 spd. with alittle head work small hyd.cam, stock comp. would get 14 mpg on highway. That's with stock 14" wheel and tire combo and stock 3:54 gearing at 65 mph.
Re: 426 hemi mpg what are you getting in yours [Re: Beebuzzn] #31619
11/24/10 08:21 PM
11/24/10 08:21 PM
USA
max Offline
super gas
max  Offline
super gas
USA
My 426 isn't anything special. Stock bore and stroke with 11.5-1 compression and stock iron heads with an M1 intake and a 750 CFM Holley along with a .525/292 cam. The car is an automatic with a stock 1800 stall convertor along with 3.31 gears.
From what I have driven the 1970 Challenger my milage is running about 10 MPG with mixed town/highway driving coarse there was a in there.
Re: 426 hemi mpg what are you getting in yours [Re: max] #31620
11/24/10 11:08 PM
11/24/10 11:08 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Kinda related...but not really... I drove a 08 duramax diesel w/allison on a 6.7 mile test drive today...trip computer said I used 1.3 gallons...I was in it a little
Oh yeah the best I got was a solid 10MPG 525 cube Stage V heads and intake, 245@ and about 550 lift. 354 Dana in E-body.
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: 426 hemi mpg what are you getting in yours [Re: TJP] #31621
11/07/12 10:42 PM
11/07/12 10:42 PM
4.26 MPG in town,
Re: 426 hemi mpg what are you getting in yours [Re: Dartman440] #31622
11/08/12 01:01 AM
11/08/12 01:01 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I get 16 miles to the gallon in a 69 RR 472 Crate motor with a single 4 barrel and 850 Holley with a Keisler 5 Speed and a 4:10 rear doing 75MPH @2200 RPM.
Same here,....the last few 472's that I fabricated 6 bbl inductions for, running Keisler TKO's .64 OD with 3:54 to 4"10's would avg about 16-18 MPG crusing at approx 80 MPH on cross country events
Mike
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31623
11/08/12 07:15 PM
11/08/12 07:15 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Relatively stock 426 Hemi 9.5 CR, mild Comp cam, 3:23 gear, automatic
about 14 mpg @ 70 mph, 3,000 RPM highway mileage.
Re: 426 hemi mpg what are you getting in yours [Re: az426john] #31624
11/08/12 11:02 PM
11/08/12 11:02 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
You guys will probably call me a liar but years ago when I move back here I drove my Hemi GTX back following my wife. She drove 55 to 60 and I never got out of the back 2 barrels. I got an honest 19mpg. I had a mild hydralic cam in it, quick advance curve in the distributer, 2" headers, 4-spd, 3.54 gears, and LR60-15's. That's the only time I ever drove it that nice, it about killed me. Dave
I am the current caretaker of Dave's GTX. The Hemi is currently 472 ci with the stock carbs, a very old (1969?) outdated and unefficient Sig Erson cam with lots of duration, and a very heavy foot on my part. I drive this car ALOT. All over New England this summer and down to NC a couple weeks ago. Even with my hard driving, she still manages just shy of 12 MPG. I am amazed! I really think that even with the current set-up, I could get 14 MPG if I would just calm down for a bit. But, that is probably not going to happen.
Re: 426 hemi mpg what are you getting in yours [Re: HemiStan] #31625
11/09/12 12:45 AM
11/09/12 12:45 AM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I just made my first small trip in my 528 hemi about 20 mi each way. It done around 8.5mpg mixed in town and hi way driving with a couple in between. Combo is Barton 528 factory inline intake 2 edelbrocks 10.5 compression 280 660 lift cam 4spd with a 373 gear. It's thirsty but it's fun.
Re: 426 hemi mpg what are you getting in yours [Re: HEMIDOG 70] #31626
11/09/12 08:06 AM
11/09/12 08:06 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
With the 605 in the truck I've checked it twice. Both times a solid 8mpg. I can live with that.Dave
Page 3 of 4 1 2 3 4
