16V POWERMASTER
#316008
05/12/09 04:06 PM
05/12/09 04:06 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
Thinking about buying a 16 volt powermater battery and charger..for the people that own them ..do you like them?
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
Post deleted by Defbob
[Re: FASTFISH420]
#316009
05/12/09 04:18 PM
05/12/09 04:18 PM
Re: 16V POWERMASTER
#316010
05/12/09 04:20 PM
05/12/09 04:20 PM
FASTFISH420
Central,Ohio
Why didn't you like???I used to run the optima batteries and loved them..just thought about switching over...
www.URE-RACING.com
Re: 16V POWERMASTER
[Re: FASTFISH420]
#316011
05/12/09 04:20 PM
05/12/09 04:20 PM
Posts: 351 michigan
64ssmax
michigan
http://www.jegs.com/i/Jacobs+Electronics/566/510064/10002/-1Take a look at this system. I hear its cats meow for good clean power.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: 16V POWERMASTER
[Re: 64ssmax]
#316012
05/12/09 05:24 PM
05/12/09 05:24 PM
Posts: 778 Sherwood park, Alberta.
go green
I have all the powermaster stuff ( 16 volt battery XS powermaster alternator and battery charger ) no problems here. Car sees 17.8 volts all the time . Second pass off the trailer I went a easy 7.90 @ 194 MPH . Should work good in your car.
[Re: FASTFISH420]
#316013
05/12/09 05:42 PM
05/12/09 05:42 PM
Re: 16V POWERMASTER
[Re: FASTFISH420]
#316015
05/12/09 09:20 PM
05/12/09 09:20 PM
Posts: 204 Indiana
MFR426
Indiana
We are running a Kinetik Racing 16 volt battery and really like it. Has more cranking amps and load amps than all the other brands. We had a problem that we now know was caused by our battery charger (Turbo Start) and they replaced the battery with no questioned asked and all I had to send to them was the vent cover and the decal. They paid all the shipping. Great customer service! Thanks! MFR426
Re: 16V POWERMASTER
[Re: MFR426]
#316016
05/12/09 09:44 PM
05/12/09 09:44 PM
Posts: 34,937 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I think its the bees knees !!
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 16V POWERMASTER
[Re: FASTFISH420]
#316019
05/12/09 10:05 PM
05/12/09 10:05 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
I've heard good things about the Powermaster batteries. We ran Turbostart batteries for years, and only had real problems seemingly as the parent company started to go downhill. I loved them. I'm still a big proponent of the 16v philosophy. In the Duster ( KB Hemi, fogger, Elec. h20 pump, 2 fuel pumps, Spal fan, 7531 ign, 10.5 tire, yadda yadda) , the pumps were "happier" at 16v. We did have issues on the day Ralph was trying to get his licence, so we swapped 2 12v batteries out of the F-250 diesel. We had one really bad battery that was dragging the other one down. In comparison, the fan almost seemed sluggish. The fuel pumps sounded anemic. And the car ran hot. We didn't see a big loss in performance, but then again, the car wasn't very consistent either. I say go for the Powermaster 16v system and follow their reccomendations.
I'm Gumby dammit!
Re: 16V POWERMASTER
[Re: sogtx]
#316023
05/13/09 05:10 PM
05/13/09 05:10 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
you will have to check into the alternator portion I don't run one ..
I'd assume i will only charge to 14 volts ?But, don't know
Re: 16V POWERMASTER
[Re: sogtx]
#316025
05/13/09 07:54 PM
05/13/09 07:54 PM
I had that set up for my Avenger never had an issue 2yrs with it.
Rob
