converting to E85
#3155422
06/29/23 09:55 PM
06/29/23 09:55 PM
Posts: 1,556 Michigan
Kiddart
I know this is a loaded question with many answers. but if you were to convert to E85 doing this with the current carb you run on your motor what kit or whom would you buy the arts and pieces from. I could buy a new e85 carb but then this one is on the shelf taking up room.
Motor 402 magnum create engine. 750 brawler race carb
Fire away any and all positive comments are welcome.
Thank you Kiddart
Re: converting to E85
[Re: Kiddart]
#3155445
06/29/23 11:25 PM
06/29/23 11:25 PM
Posts: 2,524 PA
moparacer
PA
I have a magnum 402 engine in my Barracuda I switched over to E85 years ago. Bought a Quick fuel 750 E85 carb. Took some fiddling around with it to get it right. Might be better off if you have someone convert it and can have them walk you through getting it tuned if you need help.
Mark Sullens used to be good with them. Not sure if he is still doing them or not.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: mopar873]
#3155571
06/30/23 01:42 PM
06/30/23 01:42 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
I type in Mark Sullens E85 carb conversion on my bottom search bar and it took me directly to his web site Mark Sullens E85 carb site I don't know how to post a link on any web site , sorry.
[Re: Cab_Burge]
#3155624
06/30/23 04:29 PM
06/30/23 04:29 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not sure if he’s still doing them or not but AJ Casini of Bob George Racing used to do a lot of them.
