Page 11 of 15 1 2 9 10 11 12 13 14 15
Re: Slow progress [Re: an8sec70cuda] #3140612
04/25/23 12:15 PM
04/25/23 12:15 PM
On the parachute mount
N
n20mstr Online content OP
n20mstr  Online Content OP
N
Thanks again for all the kind words
A couple more pics of some details . I separated the crank and cam synch wires , master cylinder is mounted inside firewall now
1C557644-BB44-4DE6-8B8B-31AE7E50D16E.jpeg8511F679-57E3-4572-89F5-6D0576232AB3.jpegF5FE4DB2-E124-4D1B-8BC9-E9358D1FFC2D.jpeg
....BAD A$$ STREET CAR.....
Re: Slow progress [Re: n20mstr] #3140627
04/25/23 12:54 PM
04/25/23 12:54 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Nice job on the firewall, car is looking good Tony. At any point did you consider using a Deustch bulkhead connector? I'll admit it is a bit of a PITA with the solid contact tooling but it's a nice solution.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Slow progress [Re: RMCHRGR] #3140629
04/25/23 12:58 PM
04/25/23 12:58 PM
N
N
Consider it , Sure .... can i afford the tools to do it...NO
Great job on your firewall also ! ! ! All it takes is practice , glad to see it came out nice primer
Re: Slow progress [Re: n20mstr] #3140636
04/25/23 01:19 PM
04/25/23 01:19 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Thanks. It was a lot of work.
The Deutsch crimp tool I got is an "offshore" knock off that was under $200. Still a lot of course but not $500 or whatever the real TE ones are. It's fine for what I'm doing.
Looking forward to seeing your car go down the track. Keep the updates coming!
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Slow progress [Re: RMCHRGR] #3140720
04/25/23 07:43 PM
04/25/23 07:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have used the Duetsch stuff for a few years now. Yes there is an initial investment for stuff but nice and clean way to do it. But still stuff we don't run through it. Crank trigger being one. The further we can keep it from ANY other noise source the better,
Re: Slow progress [Re: Al_Alguire] #3140745
04/25/23 10:04 PM
04/25/23 10:04 PM
How about using shielded cables for those noise sensitive circuits, like in aircraft and computers?
Re: Slow progress [Re: Cab_Burge] #3140782
04/26/23 08:07 AM
04/26/23 08:07 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Looking great and loving the attention to detail. The color combo is just perfect!
Re: Slow progress [Re: Cab_Burge] #3140820
04/26/23 10:55 AM
04/26/23 10:55 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They are already twisted and shielded wire for the crank trigger. Asd far away from any other electrical interference is the preference for me. Been there done that
Re: Slow progress [Re: Al_Alguire] #3149582
06/07/23 10:16 PM
06/07/23 10:16 PM
N
N
Been busy plumbing and wiring …..
Re: Slow progress [Re: n20mstr] #3149629
06/08/23 07:06 AM
06/08/23 07:06 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Coming along nicely thumbs
Re: Slow progress [Re: n20mstr] #3149643
06/08/23 08:32 AM
06/08/23 08:32 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Looking great. Wow. I almost understand what it all does and where it all goes to, but not quite.
Moving the radiator forward seems to create alot more space where it's needed.
Rich H.
Esse Quam Videri
Re: Slow progress [Re: ZIPPY] #3149669
06/08/23 10:34 AM
06/08/23 10:34 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
It's starting to look like a Space Shuttle! up
Re: Slow progress [Re: HardcoreB] #3149673
06/08/23 10:54 AM
06/08/23 10:54 AM
an8sec70cuda Offline
Very nice, clean, and all business!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Slow progress [Re: an8sec70cuda] #3149740
06/08/23 03:02 PM
06/08/23 03:02 PM
moparx Offline
moparx  Offline
what, or where, is the overflow tank from, and how much does it hold ?
beer
Re: Slow progress [Re: moparx] #3149778
06/08/23 04:22 PM
06/08/23 04:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
beer
Pretty sure what you are talking about is a "surge" tank. The radiator lower than the engine creates an issue. That tank allows Tony to fill the engine with water and not have any air pockets.
Looks awesome Tony cant wait to see it run.
Re: Slow progress [Re: Al_Alguire] #3150198
06/10/23 10:30 AM
06/10/23 10:30 AM
N
N
beer
It’s a 1.5 quart surge tank . If you look close , it’s fed on the bottom from the block , and there is a bung welded on the upper side to feed the radiator. There is a pressure transducer to data log coolant pressure (keep tabs on head gasket life)
Yes Al is also correct , you need a “high” spot to bleed air out of the cooling system . It solves a lot of issues
Re: Slow progress [Re: n20mstr] #3150199
06/10/23 10:32 AM
06/10/23 10:32 AM
N
N
Firecore wires , on point with service and fast turnaround. Rick is a great guy to deal with
Re: Slow progress [Re: n20mstr] #3153377
06/21/23 06:13 PM
06/21/23 06:13 PM
N
N
We have some progress here, and it cranks over up
Re: Slow progress [Re: n20mstr] #3153387
06/21/23 06:48 PM
06/21/23 06:48 PM
tboomer Offline
tboomer  Offline
Way to go Tony! up
Re: Slow progress [Re: tboomer] #3153423
06/21/23 08:45 PM
06/21/23 08:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It's going to be great t see it run.
Doug
