Re: Dash lights don't work anymore? [Re: SomeCarGuy] #314726
05/14/09 11:26 AM
05/14/09 11:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I jumped the wrong terminals at the dimmer wheel. Plenty of dash lights now. Thanks to all that helped.
I have the same issue, however the factory gauges don't work either (70 charger) what did you jump? My light switch will turn on the lights and the dimmer will turn on the dome
Coming soon!!!!
Re: Dash lights don't work anymore? [Re: Mr.Yuck] #314727
05/14/09 02:36 PM
05/14/09 02:36 PM
Someplace you aren't
SomeCarGuy Offline OP
The black and yellow wire terminal and the tan wire. I found that the tan wire is what feeds the fuse for the dash lights.
I had jumped the black/yellow to the yellow which is for the door switch or ??? That is why my dome light stayed on with the jumper.
I could kick myself now that I see it in hindsight.
Re: Dash lights don't work anymore? [Re: SomeCarGuy] #314728
05/14/09 08:50 PM
05/14/09 08:50 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I jumped the wrong terminals at the dimmer wheel. Plenty of dash lights now. Thanks to all that helped. [/quote
So was the dimmer wheel switch defective? I'm having the same issue...It's driving me nuts!!!
Re: Dash lights don't work anymore? [Re: SomeCarGuy] #314729
05/14/09 08:53 PM
05/14/09 08:53 PM
badblack68 Offline
badblack68  Offline
Re: Dash lights don't work anymore? [Re: badblack68] #314730
05/14/09 10:49 PM
05/14/09 10:49 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
It has been my experience that those old dimmer wheels usually dont work right anymore, sometimes a pencil erasure to the spring and contact helps or just jump it with a wire so they stay on full bright when the park lights are turned on....nobody dims the dash lights anyway.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Dash lights don't work anymore? [Re: mopargem] #314731
05/15/09 12:41 AM
05/15/09 12:41 AM
I have to put a little more time in and get the dome light to work also. That is the only downside to jumping the dimmer wheel. When I had the jumper on the other set of wires, it made the dome light stay on constant.
Jump the two wire terminal and the tan to get full power dash lights.
Re: Dash lights don't work anymore? [Re: SomeCarGuy] #314732
05/15/09 12:43 AM
05/15/09 12:43 AM
I might be able to breathe new life in the dimmer wheel when I have more time. It worked perfect before the car sat nearly 5 years
