need a measurement: ATI damper to block
#3145116
05/17/23 11:46 AM
05/17/23 11:46 AM
Posts: 640 Graz, Austria
DGS
Graz, Austria
Maybe someone can help me out: I need the (precise) distance between the front of a 3-ring (!) ATI Super Damper and the block face (timing cover mounting flat) for a 440 engine. This can easily be measured as the forward facing flat of the oil pump cover mounting face is on the same plane as the timing cover (next to the timing cover bolt on the right side of the picture). This is for a drawing - so suggestions for spacers etc. don't help me - I need the measurement. Thanks See AndyF's pic for reference:
Re: need a measurement: ATI damper to block
[Re: DGS]
#3145120
05/17/23 12:19 PM
05/17/23 12:19 PM
Posts: 2,674 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
ATI makes different hubs that are going to give you different measurements.
2011 Drag Pak Challenger
[Re: rickseeman]
#3145124
05/17/23 12:28 PM
05/17/23 12:28 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
ATI makes different hubs that are going to give you different measurements. There are many different three ring ATI brand dampeners for Mopar V8 motors which one are you using?
[Re: DGS]
#3145370
05/18/23 05:04 PM
05/18/23 05:04 PM
Posts: 16,929 NC
440Jim
NC
There are only two 3 ring dampers for a 440 and stock timing cover: 917122E (steel) or 917474E (aluminum). Either one should be ok for the measurement My engine is using the ATI for the Indy cover (longer damper hub), so I can't take your measurement. But here is the 917122E drawing, the damper hub goes against the timing gear face. So if you can measure from the timing gear to the block timing cover surface, you should have your info. Jim
[Re: DGS]
#3145390
05/18/23 07:23 PM
05/18/23 07:23 PM
Cab_Burge
