Project leaf spring update
#3143309
05/09/23 12:45 AM
05/09/23 12:45 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Had to change to a lighter thinner rear segment which has a bunch of stored energy I also had to remove a couple inches of lowering block to maintain the same right height we haven't set the world on fire since making the changes however I do feel like we're headed in the right direction here is a video for viewing pleasure criticism welcome.. https://youtu.be/tv0mgw_Exa8
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Project leaf spring update
[Re: WHITEDART]
#3143382
05/09/23 01:10 PM
05/09/23 01:10 PM
Posts: 4,699 On the parachute mount
n20mstr
Had to change to a lighter thinner rear segment which has a bunch of stored energy I also had to remove a couple inches of lowering block to maintain the same right height we haven't set the world on fire since making the changes however I do feel like we're headed in the right direction here is a video for viewing pleasure criticism welcome.. https://youtu.be/tv0mgw_Exa8 what criticism?? WOW that thing is working well .....MORE POWER thats all i can think of
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3143514
05/09/23 09:13 PM
05/09/23 09:13 PM
WHITEDART
bean town ....Ca
Thank you sir we'll keep chipping away at her
[Re: dvw]
#3143516
05/09/23 09:13 PM
05/09/23 09:13 PM
WHITEDART
bean town ....Ca
99% of us here wish ours worked that good. Doug .. a path that I keep chipping away at and hopes to make things better
[Re: 340Cuda]
#3143791
05/10/23 11:17 PM
05/10/23 11:17 PM
WHITEDART
bean town ....Ca
Where are you off after making these changes? 60ft is off on far but I think it will come around
[Re: HardcoreB]
#3143976
05/11/23 05:44 PM
05/11/23 05:44 PM
WHITEDART
bean town ....Ca
Very nice work! Thanks for sharing. thank you sir
[Re: WHITEDART]
#3144068
05/12/23 01:21 AM
05/12/23 01:21 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3144257
05/12/23 08:28 PM
05/12/23 08:28 PM
WHITEDART
bean town ....Ca
thank you sir it actually dropped 600 RPM on the gear change
