Need a shop to reface rocker arms
#3143197
05/08/23 01:34 PM
05/08/23 01:34 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Caution: Non-Mopar parts involved I'm rebuilding a Ford FE (390) and the rocker arm tips are badly worn. New rockers are rather expensive nowadays. Can anyone recommend a machine shop that can reface them? As usual, nobody 'round here does, so it's time to mail them out What might I expect to pay for refacing all 16 rockers? thanks for any info.
Re: Need a shop to reface rocker arms
[Re: metallicareload]
#3143213
05/08/23 03:01 PM
05/08/23 03:01 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I had a couple sets off of old hemis. They weren't severely worn but needed a "clean-up". I mounted a medium grit flap wheel in my drill press and did all the valve contact surfaces. A friend who owns a machine shop said they used to grind them years ago and said I had nothing to worry about doing them my way. Give it a shot. The material is pretty hard so the flap wheels conforms to the shape - unlike a grind stone.
[Re: DrCharles]
#3143216
05/08/23 03:14 PM
05/08/23 03:14 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used RAS when I had my Iskys done but you might want to check around at farm tractor repair shops. When I was in the equipment repair business we used to surface our rockers in house. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3143265
05/08/23 08:39 PM
05/08/23 08:39 PM
DrCharles
West Plains, MO
Thanks for the tips. RAS appears to be RAU (Unlimited) now I've sent some emails to several shops, too late to call today but I'll see if I get any replies. At least one pad, possibly another, has such a deep valve-tip-sized hole in it that it will need some weld material, though. Can't regrind that with a flap wheel and drill press, although I'm tempted to try it on the other less worn rockers... The cam is a little Crane 260-2H (204/216@.050, .501/.533 with the stock 1.73 rocker ratio) since the engine is going in a '65 dually truck. I wonder if Chinesium rockers would hold up That's under $200 for two complete assemblies, probably less than the cost of rocker rework!
[Re: Cab_Burge]
#3143341
05/09/23 09:08 AM
05/09/23 09:08 AM
Posts: 2,674 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
It's been 45 years since I've done it but there is an attachment on the end of a Kwik-Way valve grinder for that. I think it's on all of them. Worked fine. The ones I did were 426 Hemi, but I don't think that matters.
2011 Drag Pak Challenger
[Re: rickseeman]
#3143354
05/09/23 10:22 AM
05/09/23 10:22 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
There's a member here, screen name is HemiDavey. he rebuilds hemi rockers and resurfaces them. Here's his ad from the hemi parts for sale section here in the classifieds...
Please see my post from 4-5-23 for info on my Hemi Rocker restoration. Here is a real nice set Aluminum stands New Stanke shafts with removable plugs New grade 5 bolts Excellent original rocker arms, standard ratio, resurfaced New springs All parts are carefully inspected, washed and assembled correctly. Oiled and bagged for install on your engine. $2300 Sold
Please contact me by phone or text, I can text more photos to you 7 three 4 - 2 three 1- 0 seven 0 five Thanks, Dave
Dave's Hot Rod Garage (Registered repair facility in State Of Michigan) 3851 Argentine Howell, Mi 48855
[Re: Stanton]
#3143366
05/09/23 11:42 AM
05/09/23 11:42 AM
an8sec70cuda
Note that the member, whose info I shared, resurfaces rocker arms. If he can resurface hemi rockers, he likely can resurface the ford pieces the OP is working with. I only posted his for sale ad so his contact info would be shown.
[Re: DrCharles]
#3143442
05/09/23 04:44 PM
05/09/23 04:44 PM
Posts: 3,505 DFW
mr_340
DFW
I have more faith in the old iron than modern possibly melted coat hangers... Melted down coat hangars would be the high end steel in China. They save those for rods and cranks and call it 4340 (throw in an old chrome bumper in the melt).
Floyd Lippencott IV
