Re: Master Cylinder for 70 Duster 10" Drum Brakes
[Re: poorboy]
#3137571
04/13/23 12:02 AM
04/13/23 12:02 AM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
That’s disc brake master cyl. Mine has the smaller one with equal bowls and bolt to hold lid on. A long time ago the other 70 I made into a race car had the /6 with disc brakes and the smaller master, original because it still had the paint dabs on bolts, this was 1968. My 69 M-Code had 10” drums and smaller master
[Re: 70Duster]
#3137686
04/13/23 11:30 AM
04/13/23 11:30 AM
cudaman1969
fredericksburg,va
The bigger chamber-bowl is made for the front disc brakes (because it needs more volume) if plunger is same diameter it makes no difference so they stock just one size. My 72 Duster has power disc with master same as yours. The race Duster was the best stopping car I’ve ever driven, front disc and small cylinder no power. If your’s is working now I wouldn’t change it. 70 and 71 are identical
[Re: 70Duster]
#3137946
04/14/23 12:25 PM
04/14/23 12:25 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
It seems most parts houses show the bolt on lid master cylinder for the 70 Duster with 10" drums and the master cylinder like is shown in my picture above for 71 Duster with 10" drums. Why the difference? The master design change from a bolt on lid to one with a bail , but it has 2 equal size pots. Also I'm pretty sure drums masters have a built in residual valve that the report of the disc drum master does not. Drums look like this https://www.rockauto.com/en/moreinfo.php?pk=309083&cc=1231939&pt=1836&jsn=875 ... this is listed for a 1971 Duster doesn't say 10" or 9" but it does have a bore size that is bigger than a 9" listed master. I just looked at rock auto and they have a bunch of disc masters listed as for disc OR drum ... after my experience with them having the wrong shocks listed for my 98 Ram 2500 and them thinking that they can't possibly have a wrong listing so I had to pay return shipping for their F'up... I don't have a lot of faith in their listings.
[Re: 70Duster]
#3138505
04/16/23 04:35 PM
04/16/23 04:35 PM
Posts: 19,641 north of coder
moparx
sorry i didn't reply sooner, but i had tooth surgery [yanking out if you prefer ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) ] and i have been kinda flat since. i'm slightly better now. anyway, for reference, the wagner part number from my master catalog for your duster is : 506207 that fits from 1967-1970 with 10" drums, but the catalog doesn't list the bore size. however, i "think" it's 1". this is based on the 65-66 master used with 10" drums, manual or power, showing a 1" master being used. remember, those years are a SINGLE POT master, so i could be [more than likely] wrong. sure wouldn't be the first time, and won't be the last either ! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: 70Duster]
#3143066
05/07/23 04:26 PM
05/07/23 04:26 PM
Posts: 21,512 It's a dry heat
gtx6970
It's a dry heat
Correct. The one removed was a disc brake master cylinder. Agreed, And just for reference. The one installed is 1971 and later 1967 thru 1970 used the bolt down lid .
