Dustless Blasting Experiences #3142553
05/04/23 07:23 PM
05/04/23 07:23 PM
Usa
A39Coronet Offline OP
Usa
Looking for feedback from anyone who's done dustless blasting to a car. My car underbody, engine compartment, and trunk was painted (the wrong color) and I had planned to just scuff with 320 on a DA and repaint. However progress has been significantly slower than I anticipated due to the detail work and I'd hate for it to still have areas of concern.
Suncoast rents a mobile unit for $700+tax and id assume + media, which I'm contemplating. Figured I'd ask the Mopar faithful for insight.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Dustless Blasting Experiences [Re: A39Coronet] #3142565
05/04/23 07:56 PM
05/04/23 07:56 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Works great however do it on grass or a dirt lot. Makes a big mess and when it dries on asphalt it has the consistency of cement.
Abe Lincoln
Re: Dustless Blasting Experiences [Re: dart4forte] #3142575
05/04/23 08:36 PM
05/04/23 08:36 PM
Usa
Usa
Car is on a tip over jig currently but I'll make a point to put a tarp down, appreciate the info. Thankfully my driveway is flat, so hopefully the tarp keeps things somewhat manageable for cleanup if I go this route.
Re: Dustless Blasting Experiences [Re: A39Coronet] #3142619
05/05/23 12:58 AM
05/05/23 12:58 AM
New York, USA
Chargerfan68 Offline
New York, USA
Before considering Dustless Blasting, YOU MUST WATCH THIS!
Eye opening…..good information.
https://youtu.be/HKBpU20cR-M
Re: Dustless Blasting Experiences [Re: Chargerfan68] #3142648
05/05/23 09:31 AM
05/05/23 09:31 AM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
Yikes! Thanks for posting
Re: Dustless Blasting Experiences [Re: Charger727] #3142651
05/05/23 09:50 AM
05/05/23 09:50 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
First off, everything I've read about dustless blasting says to use ground glass, not sand. Would it make a difference? Don't know but that is one thing I picked up on. And then to start blasting with everything installed like door latches and window regulators? Really? And to make statements like "if you didn't know it was there", you'd have to be brain dead to think that the abrasive isn't going to get into every nook and cranny if you are careless. I look at that video as nothing more than a hit piece.
Re: Dustless Blasting Experiences [Re: 6PakBee] #3142702
05/05/23 02:41 PM
05/05/23 02:41 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
What about the dry ice blasting I have heard about a time or two?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Dustless Blasting Experiences [Re: hp383] #3142723
05/05/23 06:08 PM
05/05/23 06:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If your trying to bare metal it again 3M paint removal discs in a drill are pretty fast for the open areas.
https://www.3m.com/3M/en_US/p/d/b40070710/
Tight spots can be done with sticky back 80-120 grit on wood paint stir sticks or popsicle sticks. Having a Dremel tool with the right bits is also handy to dig paint out of corners and seams.
Re: Dustless Blasting Experiences [Re: Neil] #3142781
05/06/23 09:03 AM
05/06/23 09:03 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
If you are going to replace a panel/floor helps to remove it first so you can blast the interior rust. Same goes true with regular blasting. At least with dry blasting you can blow out most of the media. Dustlessblasting is just a pressure washer with a media blast nozzle and high price tag.
Re: Dustless Blasting Experiences [Re: Moparite] #3142791
05/06/23 10:10 AM
05/06/23 10:10 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i own two dustless set ups for my media blasting business. Dustless blasting guys claim all kind of stuff but the ONLY thing that dustless does is keep the dust down. there are zero advantages to using a dustless blaster despite what the "keyboard experts" on the internet say, dustless makes mud in places you cant get to. you use a product called hold tight 102 to add to your water tank and that holds off rust for 72 hours. you have 72 hours to try to figure out how to get the mud out. pressure wash? good plan. more water. Dont use it.
i will not ever blast wet on a car or metal for any price. No need. No point. graffiti, sailboats in ship yards, statues and concrete are all great candidates for wet blasting. not car stuff
dont fall for the hype. its great marketing is all it is. waste of money. just get yourself a good dry blast guy and you will be way farther ahead.
Re: Dustless Blasting Experiences [Re: chrisf] #3142937
05/06/23 11:39 PM
05/06/23 11:39 PM
Minnesota
RROD Offline
RROD  Offline
Minnesota
Do not mean to hijack thread but I noticed you added “weld in” frame stiffeners. Are they “U.S Tool” stiffeners? Did you weld them in on the rotisserie or before everything (weight) was removed from body. Thanks.
Re: Dustless Blasting Experiences [Re: A39Coronet] #3142983
05/07/23 09:11 AM
05/07/23 09:11 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
My youngest brother sells and repairs very large and very expensive German built +30,000 psi water dustless blasters used to prep US Navy warships and commercial Cruise ships for barnacle removal and external hull repainting.
First installation is at Portland OR dry dock but US Navy wants them everywhere to get rid of slag dust exposure to workforce and its costly much more rapid decrease in steel hull thickness. Especially submarines.
Great for big boats, but does not seem right for automobile undersides.
Re: Dustless Blasting Experiences [Re: chrisf] #3142984
05/07/23 09:20 AM
05/07/23 09:20 AM
USA
3
360view Offline
360view  Offline
3
USA
Originally Posted by chrisf
i own two dustless set ups for my media blasting business. .... you use a product called hold tight 102 to add to your water tank and that holds off rust for 72 hours.
What chemical supply company makes “Hold Tight 102”
Hold Tight Solutions ?
Re: Dustless Blasting Experiences [Re: 360view] #3142986
05/07/23 09:38 AM
05/07/23 09:38 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Have to agree to keep water off a car. I have both pressure washer blaster and dry pressure blaster made from an old compressor tank. Each have their uses depending on what you are blasting. The one i built has wheels and i didn't use brass/copper where the sand passes through. Not a good idea!
Re: Dustless Blasting Experiences [Re: 360view] #3142996
05/07/23 10:17 AM
05/07/23 10:17 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
yes. its $500+ for 5 gallons around here. its a good product for removing soda blast residue as well.
Re: Dustless Blasting Experiences [Re: chrisf] #3143004
05/07/23 11:33 AM
05/07/23 11:33 AM
birdtracker Offline
birdtracker  Offline
I have restored several complete cars that needed stripped. I am near Cincinnati Ohio and there is a place called American Metal Cleaners. I took a 1940 Plymouth body to them and all 4 doors, 2 piece hood, trunk and 4 fenders. When I got them back it was spotless. I DA everything with 40 grit and epoxyed it. Looked brand new and no sand. I took a Duster to another place that baked the paint off and then blasted with real fine black media. It was a mess and they tweaked the A-pillars from what I thought was moving the body around. Birdtracker
Re: Dustless Blasting Experiences [Re: birdtracker] #3143011
05/07/23 12:00 PM
05/07/23 12:00 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Dennis Gage recommends dustless blasting, so it's gotta be good, right? rolleyes lol
Plymouth Makes It!
Re: Dustless Blasting Experiences [Re: RoadRunnerLuva] #3143119
05/07/23 10:51 PM
05/07/23 10:51 PM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
What about dry ice or laser? Would those work.
Shawn 70 AAR
Re: Dustless Blasting Experiences [Re: birdtracker] #3143120
05/07/23 10:52 PM
05/07/23 10:52 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have used them also. Was just there about a week or so ago. It does work very well and is relatively affordable.
Re: Dustless Blasting Experiences [Re: A39Coronet] #3143779
05/10/23 10:07 PM
05/10/23 10:07 PM
Usa
Usa
Wow definitely glad I asked, I appreciate everyone's insight. Maybe just getting a small traditional dry setup and doing sections would be best. Car being tipped will make it easy, and probably won't take too much material.
