Re: Finally DONE! What will it run?!?!?
[Re: HardcoreB]
#3142607
05/04/23 10:19 PM
05/04/23 10:19 PM
Posts: 361 nj pine beach
dart9ss
nj pine beach
excellent work I'm thinking to much stall ,you might be missing the bottom end torque off the line just my .$02 I would say 5200 -5400 i would think. however its a very cool body style and build . Chop down the tree!!!
[Re: fast68plymouth]
#3142734
05/05/23 08:20 PM
05/05/23 08:20 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Unfortunately only got one semi good run in. Something is broke in the trans or converter. Pretty happy with the 1.33 60ft, and 6.23 in the 1/8th at only 106mph is promising for sure. Will get it back home and torn apart. Very good leave. Wheelie bar just keeps the front tires dancing. https://youtu.be/ELOceXIaYY0
[Re: dizuster]
#3142770
05/06/23 07:14 AM
05/06/23 07:14 AM
Posts: 4,694 Wichita
GY3
Wichita
Awesome results for a shakedown pass!
[Re: birdtracker]
#3142797
05/06/23 10:36 AM
05/06/23 10:36 AM
dizuster
Oakland, MI
I got a lot of help from a lot of people. In addition to DVW a d HardcoreB...
My mom did the lexan window straps and helped with the headliner. A friend Virginia did the carpet, Steve bent the roll cage, Kyle welded the bars, Dave built the intake spacer and welded up the valve cover, Jerry painted the motor, scoop, and wheels....and most of all my wife tolerated all of it in the middle of working and going to school to get her masters degree at the same time.
Lots of chaos, lots of help. All makes for a good life!
We will get the trans fixed up and will be back out.
[Re: dizuster]
#3142805
05/06/23 11:22 AM
05/06/23 11:22 AM
Posts: 8,174 Plymouth, MI
Blusmbl
Plymouth, MI
Awesome first pass. It'll be running solid mid 9's by the summer!
I also haven't been to Stanton in forever, nice to see it's got concrete barriers now instead of armco.
[Re: HardcoreB]
#3142813
05/06/23 11:59 AM
05/06/23 11:59 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
FWD: Somethings up with the trans, because it ran the last 300ft on the Rev limiter at 7500 rpm. But it's pretty quick already in the front half. My hat is off to all who contributed to this build. IMHO IT will eventually show itself to be a REAL overachiever, based on what is in this whole package. The 60 ft says it has power to run sub 9.80? 6.23 equals 9.80?
[Re: dvw]
#3142884
05/06/23 07:44 PM
05/06/23 07:44 PM
Posts: 1,553 Michigan
Kiddart
you guys are absolutely killing it. that car is already moving out!!
all involved should pat yourself on the back.
Thank you Kiddart
