Measurements for shifter hole #3140250
04/23/23 09:33 PM
04/23/23 09:33 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
85 D150. Converting from auto to 833OD.
Need measurements for the shifter hole as I only want to cut once and not have to weld any back in...
I do have the fiberglass tunnel extension that the trucks that came this way from the factory, had
Re: Measurements for shifter hole [Re: volaredon] #3140517
04/24/23 10:39 PM
04/24/23 10:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you have a fiberglass replacement 4 speed tunnel, you have a great template. Lay it in place, and use a marker very close around the outside of the glass tunnel, and set the glass piece aside. Determine how you are going to attach the glass to your floor, and add as much material as you will need for attachment onto the inside of the line on your floor and make another line. Cut the floor on the inside line. If you need to bend a flange to attach the glass to, you can cut a slot in the corners and bend each flange to what ever angle you need. Attach the fiberglass 4 speed tunnel to the extra material you left for attachment.
Re: Measurements for shifter hole [Re: poorboy] #3140640
04/25/23 01:37 PM
04/25/23 01:37 PM
ILLINOIS
V
V
ILLINOIS
I dunno what you mean by "replacement" 4 speed tunnel, did someone repop them? I have the fiberglass tunnel out of the same truck that is donating the trans OEM factory ,as far as I know
Re: Measurements for shifter hole [Re: volaredon] #3140644
04/25/23 02:05 PM
04/25/23 02:05 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Hey Don. Sorry I don't have any measurements and I sold my truck but here is a picture for reference.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Measurements for shifter hole [Re: volaredon] #3140646
04/25/23 02:22 PM
04/25/23 02:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Its pretty much a no brainer. The fiberglass will fit against the floor in pretty much one spot. Draw around it and that will give you a rough idea. From the factory that hole in the floor is quite large.
Re: Measurements for shifter hole [Re: moparmarks] #3140652
04/25/23 02:38 PM
04/25/23 02:38 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
Notice the large squared top transmission tunnel in the picture from Moparmarks. If your truck has the smaller, more narrow rounded tunnel, you might have different results. twocents
Re: Measurements for shifter hole [Re: Hugh Jorgan] #3140653
04/25/23 02:51 PM
04/25/23 02:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks like a normal 2wd tunnel to me.
Re: Measurements for shifter hole [Re: NITROUSN] #3140654
04/25/23 03:00 PM
04/25/23 03:00 PM
Wills Point, Texas
Wills Point, Texas
Not all 2wd trucks have the large tunnel. I just removed a small rounded tunnel from an 87 2wd to install a large tunnel (like the one in the pic) to make room for a NV4500. The OP needs to show a pic of his for proper reference.
JMHO.
Re: Measurements for shifter hole [Re: NITROUSN] #3140712
04/25/23 07:22 PM
04/25/23 07:22 PM
ILLINOIS
V
V
ILLINOIS
Yup that's exactly what mine has.
