Re: 4 Speed Dart with bench seat owners-Shifters??
[Re: topside]
#3133162
03/29/23 12:10 AM
03/29/23 12:10 AM
Posts: 20,207 Park Forest, IL
slantzilla
Park Forest, IL
I had a 70 Swinger 340 stick car. I made a straight stick about a foot long or so. It worked great for me, but I have monkey arms.
[Re: 6PAK70CUDA]
#3133351
03/29/23 03:00 PM
03/29/23 03:00 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
A body only came with 1 arm without a console , bench or buckets .
Have you friend look for a 71 B body bench shifter and a 70 bench shift b only shifter box. The 70 B only shifter box has longer arms out the bottom to shorten the throw of the long 70 B shifter length, should work nice with the longer 71 lever. I'm putting one in my 69 dart to shorten the throw.
[Re: JohnRR]
#3133440
03/29/23 06:51 PM
03/29/23 06:51 PM
Posts: 684 toronto
6PAK70CUDA
toronto
Have you friend look for a 71 B body bench shifter and a 70 bench shift b only shifter box. The 70 B only shifter box has longer arms out the bottom to shorten the throw of the long 70 B shifter length, should work nice with the longer 71 lever. I'm putting one in my 69 dart to shorten the throw. Thanks for this!
[Re: 6PAK70CUDA]
#3133558
03/30/23 08:51 AM
03/30/23 08:51 AM
JohnRR
Have your friend look for a 71 B body bench shifter and a 70 bench/console b only shifter box. The 70 B only shifter box has longer arms out the bottom to shorten the throw of the long 70 B shifter length, should work nice with the longer 71 lever. I'm putting one in my 69 dart to shorten the throw. Thanks for this! I have a little typo there , the 1970 B only shifter box is used with both bench seat shifter and the console shifter . Here is a new one for bolt on handle shifter box new Handle 71 B shifter handle
