Re: Found it!....Stupid Hemi
[Re: 6PKRTSE]
#3129066
03/13/23 02:14 PM
03/13/23 02:14 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3129071
03/13/23 02:28 PM
03/13/23 02:28 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
It will probably go in the oven and bake for a while at 120°-180° for an hour....Its brand new, but does have light oil on it.
And I got this little guy to install....
[Re: Dragula]
#3129157
03/13/23 08:06 PM
03/13/23 08:06 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I made tubular mounts that go to the core support using the factory lower radiator mounting through bolts.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3141418
04/29/23 09:09 PM
04/29/23 09:09 PM
Dragula
Well, not only am I not ready for racing, my Hemiroid has hit another snag....Last plan was to use the new block with the old rotating assembly...Got it all painted with Glyptol, got it all honed out, got the cam bearings in, got the cam in it, got pistons and assembled, polished the crank, put the crank and new bearings in the engine and torqued it all down....
Now here is where I want to thank Callies...
I got two blocks, about 2 years apart....Both are the same part number...But guess what....Callies has two different machining programs....One that has clearance for rods, and one that does not....I managed to get one of each, which we did not know about till today, when the first piston assembly went in and hit hard....Thanks Callies...
[Re: Dragula]
#3141420
04/29/23 09:29 PM
04/29/23 09:29 PM
Cab_Burge
[Re: Cab_Burge]
#3141592
04/30/23 07:06 PM
04/30/23 07:06 PM
Dragula
Well this years cam is .701 and .698....Similar duration...I hope it runs really good and keeps springs alive. It is one of their milder ramps rates and uses less required spring pressure and is a tighter lash...So we will eventually see...maybe in a couple of months.
