Small Blck 587 heads #312827
05/09/09 03:13 PM
05/09/09 03:13 PM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
I have a pair of 587 heads that I've been using on my 318. Of coarse this has caused low compression so I have them off and I'm going to have them milled.
So how far can I safely have them milled?
No longer taking $h!t from anyone!
Re: Small Blck 587 heads [Re: DUFFMAN] #312828
05/09/09 03:22 PM
05/09/09 03:22 PM
use modeling clay to see how much space you will have between the piston and the top of the combustion chamber. make sure you have a gasket on when you put the clay in. i forgot how much you should have here but im sure someone else will post with a suggestion. but for every .01 you mill i believe you have to mill .005 of each side of the intake. have you thought about going with the 302 heads?
Re: Small Blck 587 heads #312829
05/09/09 04:16 PM
05/09/09 04:16 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
My pistons are 0.054" below the deck and have valve notches in them so I'm not really worried about valve clearence.
In order for me to achieve my goal of 9.5:1 static compression I need to mill 0.065" off my 587 heads and I need to know if the heads themselves will have a problem with this.
I would love to do 302 heads, but these 587s only have about 1000 miles on them. Milling them will only cost about $150 compared to $500-600 to build a set of 302 heads. SO I'd like to go the more inexpensive route.
BTW, I'm also planning on using 0.028" gaskets along with the milling.
Re: Small Blck 587 heads [Re: DUFFMAN] #312830
05/09/09 04:22 PM
05/09/09 04:22 PM
not really sure on if they would hold up. try checking with a few machine shops and see what they say. the most ive actually seen anyone do was .03 so its hard to speculate with that much of a milling.
Re: Small Blck 587 heads [Re: DUFFMAN] #312831
05/09/09 04:59 PM
05/09/09 04:59 PM
(.065") go ahead you will be OK there
Re: Small Blck 587 heads [Re: RapidRobert] #312832
05/09/09 05:08 PM
05/09/09 05:08 PM
La Grange, Ky
70rrclone Offline
70rrclone  Offline
La Grange, Ky
i have a pair that are milled. i'm not sure how much, it was done before i got them. i have 2.08 intake valves in them and i had to notch my plastic plate to cc them and find 60CC chambers .
shane
Re: Small Blck 587 heads [Re: DUFFMAN] #312833
05/09/09 06:08 PM
05/09/09 06:08 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
i got a set of the same heads.
i milled them .060.
you'll be fine.
don't forget to have the intake side cut also.
i forget the amount, but it will help with intake manifold fitting.
Re: Small Blck 587 heads [Re: ohiodemon] #312834
05/09/09 06:34 PM
05/09/09 06:34 PM
.0095 per .010" taken off the deck but You might torque the heads & mock up/measure the intake port height alignment(head/intake match) as the above can be adjusted to get it perfect(alot depends on your choice of head gaskets)
Re: Small Blck 587 heads [Re: RapidRobert] #312835
05/09/09 07:59 PM
05/09/09 07:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If he is using the 318 port size intake the port mismatch will be negligable because they will not match the 587 heads anyway.
Re: Small Blck 587 heads [Re: MoparforLife] #312836
05/09/09 09:53 PM
05/09/09 09:53 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I'm using a 1972 340 cast iron intake. Before I took it apart the intake ports matched perfectly.
