440 distributor on a 383 #3127415
03/07/23 11:07 PM
03/07/23 11:07 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Is it still pretty close to the valve cover ?
I've thought about trying a Davis DUI distributor, but not if it won't clear.
Re: 440 distributor on a 383 [Re: hemienvy] #3127417
03/07/23 11:22 PM
03/07/23 11:22 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
They used to sell an adapter for that, the difference is only about 3/4". If you're really interested in HEI, just do the conversion with a standard distributor. 2¢
http://www.designed2drive.com/
There are numerous technical advantages to the HEI conversion, but in every day use, is it really noticeable? Kinda doubt it.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 440 distributor on a 383 [Re: hemienvy] #3127493
03/08/23 12:33 PM
03/08/23 12:33 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I like the concept of the Davis DUI but it is super tall with the big diameter cap sticking up way above the motor. I'd do the HEI conversion to a stock distributor before buying a Davis unit.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: 440 distributor on a 383 [Re: rumblefish72] #3127494
03/08/23 12:36 PM
03/08/23 12:36 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
But will it clear the valve cover ?
Re: 440 distributor on a 383 [Re: hemienvy] #3127504
03/08/23 01:36 PM
03/08/23 01:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A stock 440 distributor will clear, on the same plane as head-cover
Re: 440 distributor on a 383 [Re: cudaman1969] #3127528
03/08/23 02:46 PM
03/08/23 02:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only advantage (if you can call it that) with the Davis unit is the coil in the cap. Big deal !!
Re: 440 distributor on a 383 [Re: hemienvy] #3127531
03/08/23 02:51 PM
03/08/23 02:51 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I don't think so, I know the MSD cap-a-dapt won't fit a stock configuration. Whether a 440 RB dist will work in a std B block with an adapter? I don't think so. I can't recall ever seeing a mopar with a large cap at any of the shows I've ever attended.
'69 300 Convertible
'16 300 S Hemi
Re: 440 distributor on a 383 [Re: 3hundred] #3127540
03/08/23 03:28 PM
03/08/23 03:28 PM
an8sec70cuda Offline
That huge ridiculous looking Davis HEI thing does clear the valve cover b/c it sticks up so high. I've seen it on a couple of cars, but have no personal experience w/ it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 distributor on a 383 [Re: an8sec70cuda] #3127558
03/08/23 04:34 PM
03/08/23 04:34 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I’m all for a bigger cap for less “spark scatter,” but @ what price? I haven’t had any problems with my tiny MSD cap
lol, on Summit the description on these say they won’t clear the hood on some cars
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 440 distributor on a 383 [Re: metallicareload] #3127561
03/08/23 04:50 PM
03/08/23 04:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
These high dollar dist over a stock one is like putting a band aid over the cut before you cut yourself.
Re: 440 distributor on a 383 [Re: cudaman1969] #3127567
03/08/23 05:19 PM
03/08/23 05:19 PM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
I'm sure you know you can buy just the 4 wire module inside the HEI and remote mount it / hide it about anywhere, it's about the size of a business card and about 5/16" thick.
Accel used to make an aftermarket one, it makes for a really decent perfoming low buck HEI and it's super easy to wire.
it's great for older mopars who want to look oem and not mount a chrome/orange box in the engine compartment.
WIZE
In Car:
Re: 440 distributor on a 383 [Re: Streetwize] #3127660
03/08/23 10:15 PM
03/08/23 10:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: 440 distributor on a 383 [Re: hemienvy] #3127813
03/09/23 01:57 PM
03/09/23 01:57 PM
Quote
[/quote]But will it clear the valve cover ?[quote]
Ok - let me walk out to the detached garage and take some pictures ... My setup is B block with Edelbrock Performer RPM heads and Indy valve covers. I have a MSD Pro-Billet Distributor for RB engine in there with the Mopar Performance RB to B adapter. When I was putting this motor together, it was my first B deck motor. All my parts were RB. I never thought much about it when I put the adapter on and stabbed the distributor in. It went in without any need to grind anything. Now that you asked if it would clear, I took the picture. And it looks to me like the B version of the MSD distributor would just kiss the valve cover. For once, things went well when I used a slightly unconventional setup. I never realized this until I took the picture.
BTW - that coil mount bracket took me most of the day to whittle out of a solid block of aluminum using my drill press, belt sander and a hacksaw! After reading through this thread, maybe I'll add the HEI chip and have a one-wire ignitions setup!! Great for dyno and test stand runs!
Re: 440 distributor on a 383 [Re: rumblefish72] #3128058
03/10/23 10:27 AM
03/10/23 10:27 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks Rumblefish, so the photos are the RB distributor on the 383 ?
Re: 440 distributor on a 383 [Re: Streetwize] #3128114
03/10/23 12:38 PM
03/10/23 12:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I gutted an orange box and put the Accel unit inside it so I could use the stock distributor and wiring .
Re: 440 distributor on a 383 [Re: hemienvy] #3128118
03/10/23 12:43 PM
03/10/23 12:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As mentioned elsewhere you'll need the adaptor AND it's LONGER hold downbracket to use an RB distributor, that will push the body of the distributor up 3/4 of higher, the difference in length is below the block mounting surface.
Re: 440 distributor on a 383 [Re: JohnRR] #3128148
03/10/23 01:45 PM
03/10/23 01:45 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
That's true, and a 440 dist still would not clear the valve cover on a 383.
I wasn't sure about the DUI stuff, if that's a chev distributor casting somehow remachined for a mope,
or a modified mope distributor.
The advantage of a wide cap terminal spacing can't be denied, in any case.
Re: 440 distributor on a 383 [Re: hemienvy] #3128880
03/12/23 10:40 PM
03/12/23 10:40 PM
Photos are of the RB distributor in a B block. This particular B block is a 400 but 400 and 383 are B blocks and share the same dimension for lower distributor shaft length.
Re: 440 distributor on a 383 [Re: rumblefish72] #3129302
03/14/23 11:14 AM
03/14/23 11:14 AM
moparx Offline
moparx  Offline
several years back, i made a couple of the spacers used to adapt an RB distributor to a B block. i think i used the blueprint in the DC manual.
i never tried them to see how they worked.
beer
Re: 440 distributor on a 383 [Re: moparx] #3129308
03/14/23 11:36 AM
03/14/23 11:36 AM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
Good morning - There is one for sale in the Race Parts for Sale forum
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/3108691/11.html
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
