Will 904 Auto Trans Torque Shaft Bracket Fit 727?
#3127400
03/07/23 09:54 PM
03/07/23 09:54 PM
Posts: 597 Lost in the 70's
440gtx6
Lost in the 70's
From a little internet searching the info I found points to this bracket fitting both 904 small block and 727 big block applications. However when I place it on the 727 mounting boss, it sits at a weird angle rather than perpendicular to the frame rail. Do I need a different bracket for the big block? [img] https://imgur.com/8s5ffc3[/img]
69 EF8 GTX 440 auto 72 EB5 RR/GTX 440 auto 70 EW1 GTX 440-6 4 spd 70 EF8 Satellite 318 auto (452 coming soon) 70 FK5 Satellite 318 auto 71 FC7 Cuda 340 4 spd
Re: Will 904 Auto Trans Torque Shaft Bracket Fit 727?
[Re: 5thAve]
#3127520
03/08/23 02:24 PM
03/08/23 02:24 PM
Posts: 19,589 north of coder
moparx
when i replaced the 318/727 combo in my 74 dodge 4x4 pickup with a 440/727, all the linkage was re-used from the column shifter. with that said, i'm guessing [?] or ASSuming [ ] small block 727 passenger car 727 linkage will work with big block 727 transmissions as well. however, i have been [way] wrong in the past, and i will be [way] wrong in the future. your mileage will vary.
[Re: 440gtx6]
#3128208
03/10/23 05:24 PM
03/10/23 05:24 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
On my 67 Barracuda with automatic column shift , there is a bracket that has a stud mount with a nut that fits on the transmission , and serves as a pivot point for the bellcrank in the shift linkage . I found that if I took the stud out , and turned it around , mounting the bracket on the Bottom/ or top of the mounting pad on the transmission, it would make the linkage line up when changing between 904 and 727 transmissions . I am not sure if this is what you are talking about , or if you understand what I am saying . I am just trying to help ! Note: my car is smallblock .
------------------------ It doesn't matter what you do.........As long as you look good doing it !
