tig welding ground clamp #3125088
02/27/23 06:27 PM
02/27/23 06:27 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
I asked a few days ago about gig welding on car someone replied saying it mattered where you put the grounding clamp can someone explain where it should go and How close to the work. Thanks
Re: tig welding ground clamp [Re: dragon] #3125090
02/27/23 06:38 PM
02/27/23 06:38 PM
birdtracker Offline
birdtracker  Offline
as close to the work area as possible. Birdtracker
Re: tig welding ground clamp [Re: birdtracker] #3125168
02/28/23 12:27 AM
02/28/23 12:27 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
and on the same piece of metal.
i.e. do not put your ground clamp on an engine block or rear housing and weld on a chassis.
Re: tig welding ground clamp [Re: CMcAllister] #3125273
02/28/23 01:12 PM
02/28/23 01:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What they said..
Re: tig welding ground clamp [Re: Al_Alguire] #3125311
02/28/23 02:26 PM
02/28/23 02:26 PM
moparx Offline
moparx  Offline
whatever you do, do NOT strike the arc on the ground clamp to get started............
WHY some people do that is beyond my imagination ! i have been to many shops, and when i see ground clamps with weld boogers on them i get the creeps ! nervous panic mad
beer
Re: tig welding ground clamp [Re: moparx] #3125327
02/28/23 03:07 PM
02/28/23 03:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
beer
If you're striking an arc, you're either using a stick welder - definitely not recommended for anything close to a race car part - or you're using a stick machine with a TIG torch. Doable, but you lose being able to control the heat. If you must, use a copper pad next to where you are welding to avoid contaminating the tungsten.
I've also seen guys use the ground clamp to knock the wire back on a MIG if it got run out of the gun too far. Makes a s***mess of the clamp. For those too lazy to keep a pair of dykes handy.
