Re: 727 front pump bushing
[Re: dvw]
#3119565
02/07/23 12:06 PM
02/07/23 12:06 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
i think there are four or five different front 727 pump bushings, make sure you get the right one If there are, I've never seen any different except Babbit and bronze. Doug
[Re: Leigh]
#3119587
02/07/23 01:05 PM
02/07/23 01:05 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
There is only one size front pump bushing. Several different variations, Babbit, Bronze, Bronze w/dimples, Teflon coated, and the dry film coating. All will work, just builder preference.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: JohnRR]
#3119634
02/07/23 03:01 PM
02/07/23 03:01 PM
Posts: 9,861 MI, usa
dvw
MI, usa
i think there are four or five different front 727 pump bushings, make sure you get the right one If there are, I've never seen any different except Babbit and bronze. Doug There are at least 2 depending on the era, I think the change was 71 ? , narrow and wide. You are thinking of front drum bushings. 70 and down, narrow. 71 and up, wide. Doug
[Re: dvw]
#3119693
02/07/23 05:36 PM
02/07/23 05:36 PM
JohnRR
U.S.S.A.
i think there are four or five different front 727 pump bushings, make sure you get the right one If there are, I've never seen any different except Babbit and bronze. Doug There are at least 2 depending on the era, I think the change was 71 ? , narrow and wide. You are thinking of front drum bushings. 70 and down, narrow. 71 and up, wide. Doug correct , my bad ... I'll shut up now ...
