Re: Should a 383 4 speed burn the tires from a roll?
[Re: Kern Dog]
#3116402
01/25/23 01:32 PM
01/25/23 01:32 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
383 from a roll is a big ask to light the tires. Potentially with a clutch dump while rolling, maybe.
I want my fair share
[Re: SomeCarGuy]
#3116409
01/25/23 01:56 PM
01/25/23 01:56 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I'm going to say with what you describe , pretty much stock , no it won't . I have a 69 383 4 spd Dart GTS with 3.91's and it wouldn't break them loose on a roll ... Rev it to 4grand, sidestep the clutch and it's a different story ...
[Re: JohnRR]
#3116426
01/25/23 02:34 PM
01/25/23 02:34 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
I'm goingto say with what you describe , pretty much stock , no it won't . I have a 69 383 4 spd Dart GTS with 3.91's and it wouldn't break them loose on a roll ... Rev it to 4grand, sidestep the clutch and it's a different story ... Same here John, well sort of with my '69 GTX 440 4-speed and 3.54 and 255/60-15's on the rear it won't break rear wheels loose on a roll in the dry. Have to figure that the car on a roll has a lot of traction already to move the what nearly two-ton car, so overcoming that traction will take some torque and HP. And with Suregrip that traction is now divided by two or is that multiplied by two? At a dead stop with no tire rotation, it's easy to spin them versus overcoming the moving forward traction already there. Probably do it turning and unweighting the inside tire but difficult going straight.
[Re: A12]
#3116442
01/25/23 03:29 PM
01/25/23 03:29 PM
Posts: 701 Northern California
lilcuda
Northern California
Thanks for all the input. I will check the timing chain for stretch. It has a Hi-Rev 7500 electronic ignition on it, so I'm hoping that timing curve is decent. The initial timing is set to 12 BTDC and when I have tried to advance it further, the crappy California gas can't keep it from pinging.
After reading some of your stories, it appears I am expecting too much from a stock 383. It's a survivor, so I'm not going to hop it up. It's mostly a cruiser for me.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: A990]
#3116507
01/25/23 06:40 PM
01/25/23 06:40 PM
Posts: 19,509 north of coder
moparx
being a survivor, it's imperative to check top dead center, and if the balancer is off, look it over very carefully for deterioration of the rubber ring. in my opinion, if it has moved due to the rubber ring allowing the outer ring to move, i would replace the damper. you don't want it to come apart during "play time". after replacing the damper, check your timing closely to make sure you don't have chain issues. you will more than likely have to disassemble the distributor and weld up the weight slot, thereby allowing you to set initial timing at 15+ degrees [depending on your combination] and have 34-36 total when all in. you can start spring experimenting with removing the factory heavy spring and starting there. make sure when you have the distributor out, the weights move freely, and return to rest freely as well. you will need to check the weights and advance plate for wear or burrs, which can cause sticking to occur. after the mechanical curve is sorted, you will then need to start playing with the vacuum advance. if you can get 50ish degrees advance while cruising at ???? rpm under no load, you will obtain gas mileage you would probably not get by not using this feature on your distributor. just my own personal experience playing with distributors over the years. your mileage will vary.
[Re: moparx]
#3116537
01/25/23 08:19 PM
01/25/23 08:19 PM
Posts: 25 Verrrrry South Jersey
SpeedThrills
I see 34 and 36 degrees total mechanical timing mentioned a couple times. Waaaay back, I used 38 per the Direct Connection manual (383). Is gas that bad now? I run 35 on my 11.25:1, iron head 360 w/ 93 octane. No issues.
[Re: SpeedThrills]
#3116548
01/25/23 08:51 PM
01/25/23 08:51 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I bought my Roadrunner new after I got out of the Navy. Bone stock 383 4 speed 3.23 sure grip. It would not spin the tires on a roll. Playing with the timing didn't help. When I blew that 383 engine up while racing, I went to a 440. A 440 has been in my car ever since. It will light the tires up on a roll.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: lilcuda]
#3116570
01/25/23 09:59 PM
01/25/23 09:59 PM
Posts: 15,451 Omaha Ne
TJP
Omaha Ne
[Re: dvw]
#3116584
01/25/23 10:55 PM
01/25/23 10:55 PM
A12
N.E. OHIO, USA
Not a 383. My 9.0-1 360 will rip the 275/60's from a 10,20, almost 30 mph roll. If you you power shift with full throttle on it will keep spinning all the way thru 2nd and part of 3rd as well. 3.55 with a close ratio 2.47 1st . Yes a 383 should be able to easily brake loose. Doug Is that a bone stock 360?
[Re: A12]
#3116610
01/25/23 11:52 PM
01/25/23 11:52 PM
Posts: 10,609 Freeport IL USA
poorboy
Freeport IL USA
Back in the day I had a 70 Road Runner with a small block installed. Hemi 4 speed, 3:23 Sure Grip with L 60 15 tires and traction bars. 1st gear, clutch engaged, throttle wide open, would break the tires loose when the cam started pulling, for about a month with a new clutch, until the clutch would start to slip. The clutch was pretty much junk in about 3 months. Sure was fun while it lasted! Definitely nothing stock in that setup.
A stock 383 motor? In a drag car? I wouldn't expect it, but a few might surprise you. Some were definitely stronger then others. I beat on a lot of 383 Mopars in those days, if they hung around long, they didn't stay stock.
[Re: lilcuda]
#3116684
01/26/23 11:13 AM
01/26/23 11:13 AM
JohnRR
U.S.S.A.
Did you recurve the distributor ... shorten the mechanical advance .. before advancing it that far, Stock Chrysler distributors , even those sold thru Direct Connection and Mopar Performance, have 30 degrees of mechanical advance so it's not a wonder why it pings at higher RPM.
[Re: JohnRR]
#3116850
01/26/23 08:29 PM
01/26/23 08:29 PM
lilcuda
Northern California
Did you recurve the distributor ... shorten the mechanical advance .. before advancing it that far, Stock Chrysler distributors , even those sold thru Direct Connection and Mopar Performance, have 30 degrees of mechanical advance so it's not a wonder why it pings at higher RPM. Yeah, several people have said that. I don't know if it pings at high rpm, because when I advance it at all, it pings at lower rpm, so I back off the throttle. Clearly, I have some tuning to do.
[Re: A12]
#3116890
01/26/23 11:16 PM
01/26/23 11:16 PM
Posts: 9,863 MI, usa
dvw
MI, usa
Not a 383. My 9.0-1 360 will rip the 275/60's from a 10,20, almost 30 mph roll. If you you power shift with full throttle on it will keep spinning all the way thru 2nd and part of 3rd as well. 3.55 with a close ratio 2.47 1st . Yes a 383 should be able to easily brake loose. Doug Is that a bone stock 360? No its not. But it's pretty mild 220@.050", true 9.0-1 runs on 87 octane, 650 carb, dual plane intake, headers. Tall 27" 275/60 tires with only a 8.77 SLR. The last stock 383 I had was a 68 Dart GTS 4 speed. And yes it would spin from a roll with 255/60, 3.23, 2.66 1st 4 speed, completey untouched. Doug
[Re: lilcuda]
#3116986
01/27/23 10:47 AM
01/27/23 10:47 AM
JohnRR
U.S.S.A.
Did you recurve the distributor ... shorten the mechanical advance .. before advancing it that far, Stock Chrysler distributors , even those sold thru Direct Connection and Mopar Performance, have 30 degrees of mechanical advance so it's not a wonder why it pings at higher RPM. Yeah, several people have said that. I don't know if it pings at high rpm, because when I advance it at all, it pings at lower rpm, so I back off the throttle. Clearly, I have some tuning to do. Put the timing back to stock spec , 5BTDC till you get the distributor recurved. 4secs flat has an easy kit to limit mechanical advance.
[Re: JohnRR]
#3117021
01/27/23 12:29 PM
01/27/23 12:29 PM
TJP
Omaha Ne
With all the yes it will no it won't one thing that has not been mentioned is pavement conditions. IE: wet, dry, dry but dusty, sand, salt etc. the only stock 383 I owned that would break the tires loose on a roll was if made a right turn and nailed it in low entering the turn Straight line, dry clean pavement, NADA.
