Re: Stainless Steel Braided Line
[Re: NJK66]
#311300
05/07/09 10:46 PM
05/07/09 10:46 PM
Posts: 624 Modesto CA
BFASTER
Modesto CA
Check out paragonperformance.com
1969 Dodge Super Bee Hardtop
2007 Nissan Altima 3.5SE
[Re: BFASTER]
#311301
05/08/09 08:16 AM
05/08/09 08:16 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
when i installed my fuel lines with braided line. i was always smelling gas when the car was parked. never did find any leaks. installed hard lines the fuel smell went away.
perception is 90% of reality
[Re: Mr T2U]
#311302
05/08/09 10:28 AM
05/08/09 10:28 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I was never a fan of the do it yourself at home, fittings, I had one on my hydraulic clutch line and I suppose it did OK, but one day I accidentally snagged the line and it pulled right out. now I only use crimped fittings...much more secure!
if you wanted to run a long line for fuel, the at home fittings will probably be fine, since fuel never sees high pressure. summit and jegs both have stainless line in bulk and the fittings for each end will be around $8 each.
I bought a 25' roll of aluminum 3/8 fuel line for about $20 or so. kinda hard to beat, especially since the majority of the line is under the vehicle where no one will see it but you when you're working on it.
**Photobucket sucks**
[Re: Mr T2U]
#311303
05/08/09 10:36 AM
05/08/09 10:36 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Someone posted a while back that there was a problem with one of the braided lines seeping fuel, causing this smell.
