Re: Am I the only one with this ongoing problem?
[Re: Sammy]
#3112206
01/15/23 06:33 PM
01/15/23 06:33 PM
Posts: 215 Green Bay
Andyvh1959
Green Bay
DEF tank needs to be replaced!? The DEF tank is likely made out of polyethelene or similar plastic. Unless the DEF fuel is contaminated with silicone I really doubt a DEF tank can go bad. Or is there something integral to the DEF tank that requires it be replaced in total. Perhaps the DEF tank heater is integral to the tank? I could see a tank heater failing.
With the cost of diesel going far more than gasoline, and the fact you have to buy DEF for it as well, if you can get a good trade value for it I'd go to a gas engine. Those are WAY too many issues for a truck, that to me, for the miles is nearly new.
My 56 C3-B8 Dakota build
[Re: Andyvh1959]
#3112217
01/15/23 07:01 PM
01/15/23 07:01 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
With the cost of diesel going far more than gasoline, and the fact you have to buy DEF for it as well, if you can get a good trade value for it I'd go to a gas engine. Those are WAY too many issues for a truck, that to me, for the miles is nearly new. DEf heater went bad inside tank. DEF Fluid couldn't get contaminated. I was told never to fill it 100% and let it run down. I put in one jug each time. Every jug is sealed. Is this the norm for these diesel trucks?
[Re: 6PakBee]
#3112876
01/17/23 01:55 PM
01/17/23 01:55 PM
Posts: 4,700 North Central USA (MN-WI area)
MuscleMopars
Every day I am more thankful I bought a 2010 Cummins, the last Def-free year. Also the last year they were officially Dodges rather than Rams. 2012 was is the last year for no DEF. And I am glad I have one of those!
Thanks, Eric email eric@musclemopars.com 715-426-HEMI (Shop) 612-669-CARS (Cell and Texts)Go to my Moparts "Profile" to see my web site
[Re: J_BODY]
#3113011
01/17/23 09:21 PM
01/17/23 09:21 PM
Posts: 20,669 in a cattle trailer down by th...
Guitar Jones
I love the smell of diesel. I'll keep my old VE pumped 12 valve thank you.
[Re: Guitar Jones]
#3113033
01/17/23 09:59 PM
01/17/23 09:59 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I love the smell of diesel. I'll keep my old VE pumped 12 valve thank you. While I can see why you enjoy your tractor, I’ve come to love how much more relaxing it is to drive my 17 3500 over even my 01. I brought an 11 home back in 17 that got traded in. My mild modded 01 towed circles around it, but to be fair I’d a deleted and tuned that anyways. The 17 I have is an absolute joy to tow with. The addition of a Titan 55 tank has extended our range to 600 miles towing the race trailer.
[Re: Guitar Jones]
#3114101
01/18/23 09:36 AM
01/18/23 09:36 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I love the smell of diesel. I'll keep my old VE pumped 12 valve thank you. Is the 1992 VE 12 valve significantly different than the 1994 or 1995 Cummins 12 Valve?
[Re: 360view]
#3114121
01/18/23 10:41 AM
01/18/23 10:41 AM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Good friend has a '16 3500 he bought new. Last year at 40k miles, his went into limp mode with a DEF code. Dealer quoted him $3500(?) for all kinds of related parts. I guess they just play it safe and replace everything. ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif) Did a little research and checked the injector which was out of spec. $300 and some change later he's back on the road. So far, it's the only problem he has had with it. Hope I haven't jinxed him. ![nervous nervous](/ubbthreads/images/graemlins/custom/nervous.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: J_BODY]
#3115605
01/23/23 09:53 AM
01/23/23 09:53 AM
Andyvh1959
Green Bay
To the person who posted about working at a Peterbuilt dealership and seeing all kinds of DEF issues, can you list them for us? It'd be interesting to understand how many are system issues, design issues, user issues, etc.
[Re: 360view]
#3116527
01/25/23 07:30 PM
01/25/23 07:30 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I love the smell of diesel. I'll keep my old VE pumped 12 valve thank you. Is the 1992 VE 12 valve significantly different than the 1994 or 1995 Cummins 12 Valve? The engine it self is the same. The only diesel I ever owned that I like was my old 12V VE pump, I ran it off used oil at the honda dealer I worked at. It was quite easy to turn up the power just a little from turning a couple screws and was very reliable and had a really neat feel but my 2011 2500 Ram with my "special built" 6.4 hemi tows a lot better and gets almost as good MPG as the old 12 valve did.
