Re: Six Pack carb parts [Re: jlatessa] #3112740
01/16/23 10:48 PM
01/16/23 10:48 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Has anyone here had any problems with the floats hitting the plates?
Re: Six Pack carb parts [Re: formula S] #3112794
01/17/23 06:45 AM
01/17/23 06:45 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Only with longer jets.
Real Men shift for themselves
Re: Six Pack carb parts [Re: 1DGEMAN] #3124730
02/26/23 10:34 AM
02/26/23 10:34 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
They Fit Nicely
with normal jets
Re: Six Pack carb parts [Re: sogtx] #3126152
03/03/23 12:09 PM
03/03/23 12:09 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
You can actually modify the stock metering plates to accept jets. Plug the orifices with lead and drill and tap for jets.
Re: Six Pack carb parts [Re: R/T1968R/T] #3131200
03/21/23 07:12 PM
03/21/23 07:12 PM
Indiana
maxie Offline
maxie  Offline
Indiana
We put the promax plates on my car two weeks ago. Do a little search on the internet about Bob K and he shows how to jet them. I understand every car is a little different but he gives a good base line of where to start.
Re: Six Pack carb parts [Re: formula S] #3131329
03/22/23 08:17 AM
03/22/23 08:17 AM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
I have... I never figured out the root cause of the issue other than float and bowl tolerance stack up. Some of the float designs were slightly closer to the plate than others. We had to file down the parting line on a nitrophyl float on the dyno to finish the day.
Re: Six Pack carb parts [Re: jlatessa] #3131595
03/22/23 11:40 PM
03/22/23 11:40 PM
Cab_Burge Online work
Cab_Burge  Online Work
[quote=jlatess
The best results were 1/8 or a 1/4 turn off the seat.Joe [/quote] iagree
Re: Six Pack carb parts [Re: RoadRunnerJD] #3143237
05/08/23 05:22 PM
05/08/23 05:22 PM
Chicago
PurpleBeeper Offline
Chicago
I'm running the Promax plates in my outboards. I think my '70 carbs uses a 34 & a 35 plate and I couldn't find one of them (one is common, the other isn't) & my plates had been drilled. I was trying to get back to "factory settings". After extensive research, I put in jets that matched the stock metering plate holes AND changed out the secondary idle feed restrictions. I had to call Promax to get the idle feel restrictors (not on their website) and they had some the correct size (pretty cheap, but I did have to put a propane torch on one to get it out)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Six Pack carb parts [Re: PurpleBeeper] #3143311
05/09/23 01:02 AM
05/09/23 01:02 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Quick fuel also makes the jetable plates.
STOP POTATO HATE!
