Page 5 of 6 1 2 3 4 5 6
Re: 'new' engine UPDATES 440-1cnc [Re: Al_Alguire] #3183399
10/12/23 03:08 PM
10/12/23 03:08 PM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
Originally Posted by Al_Alguire
Would look better with different heads boogie
Thanks again everyone! Noone in their right mind would argue there.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3183414
10/12/23 04:00 PM
10/12/23 04:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
But you dont need those fancy valve covers. I know a guy who could thoough smile Even send oyu some nice fabbed aluminum ones maybe even a tunnel ram smile
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3183531
10/13/23 07:14 AM
10/13/23 07:14 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Headers and plug changes look like FUN on that!
Re: 'new' engine UPDATES 440-1cnc [Re: fbs63] #3183537
10/13/23 08:48 AM
10/13/23 08:48 AM
Shelby Twp. Mi
Shelby Twp. Mi
Headers aren't really bad! These were made by Ernie M (local guy) for John Burdine For a B body RB engine. John was generous to sell them. Six of the eight are almost a bolt-in and two need remade. I didnt check for plug access but it can't be bad? IDK And I won't know soon because I took that mock-up out last night to make room for the KB/440-1 install! I have to say I owning and handling the Predator stuff now makes me reevaluate (at this point in time/race season's is over) why I'm playing with the 'inferior' top-ends.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3183542
10/13/23 09:15 AM
10/13/23 09:15 AM
Shelby Twp. Mi
Shelby Twp. Mi
One of the differences on this block is lack of china-wall oil ports which i was using for my idiot light sensor and to feed valvespring oilers. So my idea is to use the NPT ports on the side of the block, I'm always open to other suggestions... Apparently someone didn't want anyone EVER to remove these internal hex NPT plugs because they cranked them in all the way to China! I assume it's because they didn't want to use any NPT sealer so, tight is right? IDFK So, I had to get creative because tapping-in the metric oversize allen wrench still stripped out the hex, Whiskey Tango Foxtrot.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3184555
10/17/23 08:51 AM
10/17/23 08:51 AM
Shelby Twp. Mi
Shelby Twp. Mi
I made a little shockproof tab mount for the psi sensor and valvecover feeds. Also used a port in the side of the block for oil temp. I added magnetic tipped NPT plugs in the ports which is a nice feature...not that I'll need it?!
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3184558
10/17/23 09:00 AM
10/17/23 09:00 AM
Shelby Twp. Mi
Shelby Twp. Mi
Since I had to increase my oil pump speed, (it's an older NASCAR pump I converted from 6 to 5 stage and it uses a small pressure section) I clearanced the oil pan and pump mounts for more belt travel/adjustment and Jones pulleys sent me a couple new gilmer belts ( always get a spare) . This 'fix' created a new problem because the fittings underneath now collide with the rack and pinion mount...always something!
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3184559
10/17/23 09:07 AM
10/17/23 09:07 AM
Shelby Twp. Mi
Shelby Twp. Mi
But it's in the car now! Hopefully accessorized and running after another few days of work. I tried to do as much as I can to minimize any assembly with the engine in the car because, I've found it's faster and less frustrating and better executed in-general. But sometimes, things are such a tight fit, you just need the engine in the car.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189293
11/07/23 10:24 AM
11/07/23 10:24 AM
Shelby Twp. Mi
Shelby Twp. Mi
Just some updates and since the season is over the priority is shifted on better detailing and less shot-gun work. You'd think because i basically reused the oiling system and transmission that I wouldn't have to reengineer related stuff...New lines and routing allow easier belt tension and access while speeding up the old pump to near it's rpm limit.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189296
11/07/23 10:27 AM
11/07/23 10:27 AM
Shelby Twp. Mi
Shelby Twp. Mi
In the meantime, I decided to upgrade the collectors from 3.5 to 4" and added o2 bungs (tight packaging)
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189297
11/07/23 10:29 AM
11/07/23 10:29 AM
Shelby Twp. Mi
Shelby Twp. Mi
Somewhere else (on another post?) I shared where I put my OFA which has a mechanical gage clocked so i can see it when i prime the oil.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189300
11/07/23 10:37 AM
11/07/23 10:37 AM
Shelby Twp. Mi
Shelby Twp. Mi
Also under the same theme of correcting things that were marginally functional before, I took care of some wiring because it's easier to access thru the trans tunnel (with no trans). For some reason the Holley system has a NOISY tach signal until higher RPM/on the converter. So they sold me a 'filter' guess we'll see how that works!
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189301
11/07/23 10:44 AM
11/07/23 10:44 AM
Shelby Twp. Mi
Shelby Twp. Mi
In consideration of the scaling-up, in addition to porting the intake to the larger heads, I also made a larger plenum spacer. I'll probably swap-out the 1.38 downleg airhorns to some 1.59 annulars I bought quite a few years ago with the thought they'd lend themselves to oxygenated fuel better.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189304
11/07/23 10:55 AM
11/07/23 10:55 AM
Shelby Twp. Mi
Shelby Twp. Mi
Also for posterity, when using a powerglide etc. it appears you're pretty much going to have to figure out flexplates, midplates, converters and starters as you go. The block, the crank and etc are all variables.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189305
11/07/23 11:03 AM
11/07/23 11:03 AM
Shelby Twp. Mi
Shelby Twp. Mi
Almost forgot! I really should have sorted-out the alternator on the stand but in my haste I was going to skip running one altogether and convert to 16V. I did buy a 20lb lighter 16V battery but since the season is over I sunk the alternator into the motorplate.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189308
11/07/23 11:14 AM
11/07/23 11:14 AM
Shelby Twp. Mi
Shelby Twp. Mi
I also couldn't live with the coil being red so I painted it. laugh
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189420
11/07/23 04:26 PM
11/07/23 04:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Hey are you doing cars shows or racing? Come on now.
Doug
Re: 'new' engine UPDATES 440-1cnc [Re: dvw] #3189427
11/07/23 04:51 PM
11/07/23 04:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Doug
Says this guy smoke
Re: 'new' engine UPDATES 440-1cnc [Re: Al_Alguire] #3189428
11/07/23 04:52 PM
11/07/23 04:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looking good. And the glide, BBM thing has gotten kinda out of hand. I have never really had many issues with this before but dang sure do now....Looking good!!
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3189913
11/09/23 07:07 PM
11/09/23 07:07 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Nice valve covers,I believe those covers once belonged to Tom Debartalo. I believe the guy you bought those from, I sold a set of new T&D rocker stands to. There is one set left of billet covers that were never used to my knowledge .. he is or was a member here,the guy in Australia that used to run drag week with a silver Predator headed drag drive car. as far as I know he never use them, might do some foot work if someone wanted a pair. I still do on the program for these if I was able to sell five sets, I could have more made
