Re: B body power steering effort left to right
[Re: Pacnorthcuda]
#3109866
01/07/23 07:01 PM
01/07/23 07:01 PM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
GTX, there is a valve at the top of the box where the pressure line attaches. It’s a plate with two mounting bolts. If you loosen the plate bolts the plate can slide a bit…which makes a BIG difference in how the steering pulls one way or the other. You adjust this with the wheels hanging in the air, engine idling. Many people don’t know about that adjustment. Im familiar with the adjustment you mention. Ive had the front in the air and running. ...it doesn't turn . Nor does it pull driving down the road
[Re: Cab_Burge]
#3130859
03/20/23 02:42 PM
03/20/23 02:42 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
When adjusting that valve body (on top of the gear box), I highly recommend not just having the front wheels off the ground, but to have the front wheels removed from the spindles. You want as little friction (weight) as possible so to assure the power assist of the left-right-left-right action is at a minimum of the gear box.... IF you wanted to go a slightly different and better route, you could alternatively disconnect the Pitman Arm from the steering link cross-arm (letting that hang)... again, reducing all possible friction from the gear box. That's how I've done it in the past... best results!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: captaindodge]
#3142065
05/02/23 04:46 PM
05/02/23 04:46 PM
Mopar Mitch
I don't recall how much movement there actually is, but I'd think there is more than 0.02"... perhaps maybe 1/16" for and aft?
Mopar Mitch
[Re: captaindodge]
#3142707
05/05/23 03:07 PM
05/05/23 03:07 PM
Mopar Mitch
Sounds a little confusing... when the engine turns off... there shouldn't be any further assist in either direction.
Mopar Mitch
[Re: Mopar Mitch]
#3142738
05/05/23 08:51 PM
05/05/23 08:51 PM
Posts: 5,917 ohio
ruderunner
ohio
Otoh, there shouldn't be any movement when he start the engine.
This might be a 2 angle problem.
One, incorrect adjustment of the centering valve. Explains the movement of the steering wheel engine running or not
Two, might be excessive friction in steering joints. For example a frozen tie rod end. Or, my hunch, too much preload on the sector shaft.
A bit of work but, what happens if you drop the pitman arm? Does the steering turn by itself if you start the engine?
Angry white pureblood male
[Re: captaindodge]
#3142964
05/07/23 06:07 AM
05/07/23 06:07 AM
Posts: 5,917 ohio
ruderunner
ohio
Air in one or the other chamber is a possibility.
The long pitman should affect both directions equally.
[Re: captaindodge]
#3143399
05/09/23 02:46 PM
05/09/23 02:46 PM
Mopar Mitch
Hopefully, along with the "long Pitman arm"... you are also using the long Idler arm... simply a ~1970 C-Body (Fury) idler arm. Sellers often refer to this as the "fast ratio IDLER ARM"... its simply a longer idler arm that should've been factory installed on the E-bodies having optional "Fast Ratio" power steering which comes with the longer "FAST RATIO PITMAN ARM". IF only the longer Pitman arm is used, then the turning radius is different Left vs Right... it was a factory mistake/oversight on those E-bodies with the optional Fast Ratio power steering. No company (Firm Feel, Hotchkis, PST, others, etc) ever developed a "Fast Ratio IDLER ARM"... it has always been and always will be simply a ~1970 C-Body (Fury) idler arm.
Mopar Mitch
[Re: Mopar Mitch]
#3143655
05/10/23 01:44 PM
05/10/23 01:44 PM
Posts: 19,548 north of coder
moparx
mevotech #M525940 - $27.79 moog # K7014 - $50.99 rock auto prices as of a few minutes ago. they also give delphi #TA593 and centric #62063005, but list those numbers as out of stock. these parts may be available elsewhere, but i didn't check. [these are the 1970 C-body idler that Mitch mentioned above]
