Almost 2 year in the making...
#3101512
12/12/22 08:32 AM
12/12/22 08:32 AM
Posts: 10,166 A Red State
SNK-EYZ
A Red State
It's been almost 2 years since the rebuild/stroker upgrade was started on the wife's 2006 Charger Daytona 5.7. It started with the dreaded valve seat fallout at 220k miles on the 5.7 Hemi. Rather than just a stock rebuild it got an upgrade to a 6.4 stroker kit and upgraded to a set of 2014 Eagle heads. It's getting a 6.1 factory intake with a custom ground camshaft, stainless long tube headers and high flow cats. The whole pandemic BS mean it took forever to get machine work done. I was finally able to pick it up from the engine builder last night. WooHoo!!! Next step is painting it, Hemi Orange of course. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
Re: Almost 2 year in the making...
[Re: A39Coronet]
#3101806
12/13/22 01:06 AM
12/13/22 01:06 AM
SNK-EYZ
A Red State
I'll be curious to see what you do for paint, rattle can or spray gun, and what all will get color. I'm pre paint currently, trying to figure out what to do for the heads, if I want to leave them natural, paint them aluminum, or paint the orange. Same with the front cover. I'm planning on using Ditzler/PPG Urethane Hemi Orange (without gold metallic) paint (sprayed with a gun obviously) that I already have. I'm planning on painting pretty much everything but the valve covers. I may skip painting the oil pan though, undecided on that yet. Other than the heads, most of the aluminum stuff has enough wear/tarnish that I thing it will look better painted. As far as the other question posed, If it's in the ballpark of a 6.4 the wife will be happy. It's still going to see life in nice weather as her daily driver so she didn't want to go radical with it. As long as she can do bigger smoky burnouts with it she'll be happy. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: Dyno1]
#3101951
12/13/22 02:38 PM
12/13/22 02:38 PM
SNK-EYZ
A Red State
On this build for her car looks are probably more important than getting ever last possible bit of horsepower. As long as it sounds good and has more power than it had (it was rated at 345 hp stock) she'll be happy. That and she just wants her car running again. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) The 6.1 in my 2010 Challenger SRT did 417 rwhp with the mods it has. If her Charger is in that ballpark she'll be really happy. ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif)
[Re: Dart 500]
#3102973
12/16/22 08:46 PM
12/16/22 08:46 PM
SNK-EYZ
A Red State
6.4 intake is far superior and is better than 20hp. It switches from short ram to long ram, engine masters tested it and it was eye watering how good they work. Not sure it fits an older non VCT hemi though The cars computer is pre VVT and pre split runner so there's no reason to even try to use the later intake. I've got the Engine Masters DVR'd that compares the intakes, from memory the biggest difference was a broader and flatter torque curve and a gain of HP at a high rpm. As already stated, I don't care about gaining every last bit of HP, it will have far more that it ever did in 2006 so the wife will be happy with it. I have a truck split runner intake from the 2014 engine that the heads came off, eventually it will be sold as I have no use for it.
[Re: redraptor]
#3103236
12/18/22 09:28 AM
12/18/22 09:28 AM
Posts: 885 south louisiana
lowell66dart
south louisiana
[Picked up a 2007 R/T in limp mode a few month ago for a song. It's got a truck long block in it and I have it running really well but I am looking around for a 6.1 to drop in with just a cam swap maybe. If that falls thru I will be doing something like your doing. Keep us posted.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: SNK-EYZ]
#3103490
12/19/22 01:25 AM
12/19/22 01:25 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I'll be curious to see what you do for paint, rattle can or spray gun, and what all will get color. I'm pre paint currently, trying to figure out what to do for the heads, if I want to leave them natural, paint them aluminum, or paint the orange. Same with the front cover. I'm planning on using Ditzler/PPG Urethane Hemi Orange (without gold metallic) paint (sprayed with a gun obviously) that I already have. I'm planning on painting pretty much everything but the valve covers. I may skip painting the oil pan though, undecided on that yet. Other than the heads, most of the aluminum stuff has enough wear/tarnish that I thing it will look better painted. This is GoManGo without the metallic. It is quite tangy!
[Re: Kern Dog]
#3103500
12/19/22 04:56 AM
12/19/22 04:56 AM
SNK-EYZ
A Red State
It'll get painted with the same batch of Hemi Orange paint that I painted the Dart's engine with. It looked better before the front carb fuel line broke and it caught fire at the track in October. ![ozbbq ozbbq](/ubbthreads/images/graemlins/custom/OzBBQed.gif)
[Re: Kern Dog]
#3103541
12/19/22 10:57 AM
12/19/22 10:57 AM
Posts: 1,559 Michigan
Kiddart
I'll be curious to see what you do for paint, rattle can or spray gun, and what all will get color. I'm pre paint currently, trying to figure out what to do for the heads, if I want to leave them natural, paint them aluminum, or paint the orange. Same with the front cover. I'm planning on using Ditzler/PPG Urethane Hemi Orange (without gold metallic) paint (sprayed with a gun obviously) that I already have. I'm planning on painting pretty much everything but the valve covers. I may skip painting the oil pan though, undecided on that yet. Other than the heads, most of the aluminum stuff has enough wear/tarnish that I thing it will look better painted. This is GoManGo without the metallic. It is quite tangy! that is super Bright!!! I like it!! thank you for sharing
Thank you Kiddart
[Re: Kern Dog]
#3103734
12/19/22 09:06 PM
12/19/22 09:06 PM
SNK-EYZ
A Red State
I'll be curious to see what you do for paint, rattle can or spray gun, and what all will get color. I'm pre paint currently, trying to figure out what to do for the heads, if I want to leave them natural, paint them aluminum, or paint the orange. Same with the front cover. I'm planning on using Ditzler/PPG Urethane Hemi Orange (without gold metallic) paint (sprayed with a gun obviously) that I already have. I'm planning on painting pretty much everything but the valve covers. I may skip painting the oil pan though, undecided on that yet. Other than the heads, most of the aluminum stuff has enough wear/tarnish that I thing it will look better painted. This is GoManGo without the metallic. It is quite tangy! It does really look good. I'm surprised that it doesn't really look lighter in color than the Hemi Orange that I've been spraying. Usually GoManGo/Vitamin C Orange looks paler/lighter in color.
[Re: Kern Dog]
#3116286
01/25/23 06:13 AM
01/25/23 06:13 AM
SNK-EYZ
A Red State
I painted the engine Hemi Orange today. I used the last of the PPG Deltron single stage urethane that I had. I guess it's time to get more mixed up, I've been using that quart for about 20 years now to paint engines. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) The intake still needs cleaned up, I just set it on there to take pics. I'm trying to decide whether to have it ceramic coated or powder coated to keep the finish nice on it...
[Re: Cab_Burge]
#3116577
01/25/23 10:23 PM
01/25/23 10:23 PM
SNK-EYZ
A Red State
Powder coating keeps heat in aluminum manifolds ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I found that out the hard way ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) Same thing on valve covers, don't do that It may just get cleaned up and left bare then.
