Re: Cross Ram - inside work - dividers / block offs.....
[Re: GomangoCuda]
#310042
05/08/09 02:15 PM
05/08/09 02:15 PM
BradH
I have an intake that almost nobody has messed with.....and I like it that way
I understand the "being different" aspect. But there comes a point where the PITA factor associated w/ taking that approach comes back to haunt you... especially when you're trying to sort out a combination that was never intended to work well under those conditions.
[Re: GomangoCuda]
#310043
05/08/09 02:18 PM
05/08/09 02:18 PM
Posts: 4,573 ...gently down the stream
LAR_414
If I was interested in going fast all the time, I'd put something else on. My car isn't a race car. I feel that I've already proven that the STR-12 isn't junk. I'm getting 3mpg better gas milege with this vs my Home ported M1 single plane with home built 900+cfm carb. That old combo had no issues and was tuned very very well, both at the track and on the street. This intake setup was worth 3mpg / 2mph and about .2 et over the old combo. This is in the same car, same track, same conditions. I'll stick with it for now
[Re: LAR_414]
#310046
05/08/09 03:31 PM
05/08/09 03:31 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
"11.07 and 120.4 mph 15.5 mpg(highway) pump gas small block, Cross Ram."
Kinda' speaks for itself.
Keep marchin' to the beat of a different drummer - it seems to be workin' for ya'!
I think you're onto a good idea in checking what more/less timing does; cheap and easily undone.
What about messing w/ air bleeds? I've found a number of cars I've worked on went a little lean off-idle, right where they'd spend a good portion of time cruising. Just a thought...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: LAR_414]
#310050
07/10/09 12:49 PM
07/10/09 12:49 PM
LAR_414
Update, Made large sheet metal dome under each carb to direct the fuel and reduce volume. Pretty sweet job, if I don't say so myself. Took a great deal of volume out of the intake, and keeps the fuel from puddling directly under the carb in a large dead area.
No change! Still bucks and kicks as it always has.
SO I've done the following and noticed no change: -Played and played and played with carbs, with A/F monitor hooked up. Went Rich / Lean and everyhwere inbetween. IFR changed, IAB changed, Open rear blades more than front, vice versa,..... -Timing all over the place from locked out low / normal / high. Curve from BTDC to very little...all maxed out to the same 35 degrees or so. -Changed the intake shape a bit to aid distribution and signal to carb, taking volume out -Added 4 hole spacers 1" thick -Increased valve lash about .006"
Nothing has changed the problem yet.
Cam too big? 260 @ .050 on 110LSA installed at 106 Solid fast ramp.
