Re: No Prep Kings - What am I missing?
[Re: A39Coronet]
#3098762
12/01/22 07:43 PM
12/01/22 07:43 PM
Posts: 20,913 A collage of whims
topside
A collage of whims
Interesting. Looks like both are kinda high, but you could be right. Goofy-looking things; I get it, but would rather they not have them. I'd be the guy who'd trip over one
[Re: A39Coronet]
#3098787
12/01/22 09:08 PM
12/01/22 09:08 PM
Posts: 15,526 Omaha Ne
TJP
Omaha Ne
[Re: SV_MOPARS]
#3098795
12/01/22 09:45 PM
12/01/22 09:45 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If your frontend rides high you will lose a close race if the others guys stripe taker hits the beam and your front tire takes the stripe. He’s new and will fix his car.
[Re: pittsburghracer]
#3098800
12/01/22 10:19 PM
12/01/22 10:19 PM
Posts: 1,115 Usa
A39Coronet
Usa
I shut it off after that race, did they address it on the show/after the event?
[Re: theraif]
#3098931
12/02/22 01:02 PM
12/02/22 01:02 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
The same thing happened to Daddy Dave a few races ago. Those guys need to get their front ends down at speed. DD's car always looks like it's going uphill.
[Re: slantzilla]
#3098979
12/02/22 04:13 PM
12/02/22 04:13 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
The finish line lights at the end of the track are mounted higher than ones on the starting lines at NHRA sanction track, Finish lines lights are supposed to be 6.0 inches high to the centers from up the ground, the starting lines lights are 3.0 inches to the center is what I've been told by several local strip techs and by NHRA headquarter tech people NHRA did increase the legal limit on the length of them from 36.0 inches to 42.0 measured off of the furthest forward spindle several years back based on that some of the newer cars having longer noses This a fine example of the need to raise the finish line heights up to 12.0 inches or higher
[Re: justinp61]
#3099041
12/02/22 06:53 PM
12/02/22 06:53 PM
slantzilla
Park Forest, IL
You can see where the reflector is on the block. The extender has to be low enough to hit the beam. In this case it appears it's over the top of the block.
[Re: A39Coronet]
#3099058
12/02/22 07:34 PM
12/02/22 07:34 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not with this series, but how do any of the sanctioning bodies handle this scenario if a racer brings video evidence? Would a win light ever be overturned or is it the end all be all? Hmmmm not really sure but camera angle is so important. I saw several videos of this race and man Jerry was really closing in on him at the finish line. From two feet back you figured no way. Funny thing is if Brandon would have played bracket racer and left off the gas he would have won. Lol. I do know a pro stock motorcycle race was overturned years ago.
#3099121
12/03/22 12:46 AM
12/03/22 12:46 AM
slantzilla
Park Forest, IL
Steve Johnson got a win at the US Nationals years ago with video.
One thing you have to remember with the NPK races, these guys have already split the money by the time they get to 4 cars.
Brandon's car is so high he tripped the beam with his front wheel, Jerry beat him to the beam with a lower car.
