Re: Theives breaking in to cars....
[Re: Ramrod39]
#3096785
11/24/22 11:51 AM
11/24/22 11:51 AM
Posts: 1,707 central il.
second 70
central il.
Don't know the answer to your question but I would put a Club on the steering wheel. 10 seconds to defeat The Club with a pair of bolt cutters. Would not stop a motivated thief, the kind who had a key made. Better than nothing when it comes to some random thief looking for a random target though. OK, I'm curious. How do you defeat a club in 10 seconds with just a pair of bolt cutters? I use bolt cutters on occasion to remove padlocks and I see no way to cut a club off with a pair. Unless they are maybe 6 feet long... You cut the steering wheel not the club. Most outer rings are plastic coated metal and easy to cut. Thieves just carry a hack saw blade in their pocket.
[Re: TJP]
#3096799
11/24/22 12:18 PM
11/24/22 12:18 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
The side glass is on nearly all new cars are "Snap In" Not bolted in like the old ones we love. With a little patience it isn't hard to unsnap the glass and remove it from the car with the door shut. Look on Youtube and there are several porch cam videos of people removing the glass and getting into the cars. Could you post a link? couldn't find what you were referring to I have not replaced the side glass on a new challenger but I have on multiple others models. Hence the nearly all statement because I can not say everyone is like that, but all of them I have replaced made in the last 10 years or so were snap in glass. The most common breakage point from my experience is the glass sticks in the track and causes the snap to pop loose and the glass comes loose. Usually without breaking the glass but often the regulator has to be replaced. Maybe it isn't as common as I think but is the most common repair I have had to deal with. My apologies if I had the wrong impression of the problem. This is one video that shows the guy remove the glass in one piece. There are others but I can't find the one I was looking for. https://www.youtube.com/watch?v=E69xDrxAWzQScroll to 1:14 and you see him remove the glass in one piece.
[Re: J_BODY]
#3096843
11/24/22 03:04 PM
11/24/22 03:04 PM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
The pin for key programming is NOT in the owners manual….. unless you wrote it there. IF you lose a key, fear one was stolen, nefarious ex has one, we can blank all keys and reprogram the ones in your possession.
With the ease of being able to steal my 01 Ram I’d always disable the injector pump and remove the starter relay. The pickup was excellent condition and I couldn’t afford to lose it easily.
With the departure of the 01 and the arrival of the 17 3500 I started researching if they too were stolen with some frequency. The informative videos on the theft of newer vehicles was astounding. While there’s great technology to prevent this built in, theirs even greater tech making it possible.
And anyone on FB it seems we’ll see at least once a week someone who’s mid 2000s Ford F-350 that has disappeared. That's kinda what I thought, it wouldn't be in the manual unless someone specifically puts it there. He'll be at our house for Thanksgiving today and I'm sure we'll be discussing it. IF you lose a key, fear one was stolen, nefarious ex has one, we can blank all keys and reprogram the ones in your possession. I'll let him know that. Has anyone put an old fashioned "Kill Switch" on a late model vehicle??? You know, like one that would simply short out the negative side of the coil on an old car. I'm not sure how it would work on a computerized car.
[Re: SNK-EYZ]
#3096856
11/24/22 04:03 PM
11/24/22 04:03 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
There are quite a few deactivation systems available for late model stuff. I know a guy who got his F-350 King Ranch stolen. All they did was sit in his driveway and put a new key switch in it. He got it back and installed a starter relay and fuel pump relay that will not activate without a code from his phone.
[Re: IMGTX]
#3096930
11/24/22 11:15 PM
11/24/22 11:15 PM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
The side glass is on nearly all new cars are "Snap In" Not bolted in like the old ones we love. With a little patience it isn't hard to unsnap the glass and remove it from the car with the door shut. Look on Youtube and there are several porch cam videos of people removing the glass and getting into the cars. Could you post a link? couldn't find what you were referring to I have not replaced the side glass on a new challenger but I have on multiple others models. Hence the nearly all statement because I can not say everyone is like that, but all of them I have replaced made in the last 10 years or so were snap in glass. The most common breakage point from my experience is the glass sticks in the track and causes the snap to pop loose and the glass comes loose. Usually without breaking the glass but often the regulator has to be replaced. Maybe it isn't as common as I think but is the most common repair I have had to deal with. My apologies if I had the wrong impression of the problem. This is one video that shows the guy remove the glass in one piece. There are others but I can't find the one I was looking for. https://www.youtube.com/watch?v=E69xDrxAWzQScroll to 1:14 and you see him remove the glass in one piece. thank you
[Re: TJP]
#3097796
11/28/22 02:33 PM
11/28/22 02:33 PM
Posts: 1,550 Michigan
Kiddart
Just this weekend Christe Lee from motor trend her new Hellcat was stolen right out of her driveway. It was all over Instagram. took all of 40 seconds. they do something under the dash on the passenger side car starts up and off they go. someone posted that with a simple electronic code scanner you can walk by something that is Wi-Fi accessible and the code pops up and you can unlock car then get to whatever they need to start the car. it sucked watching the video. someone also said this scanner thing picks up the fob in your house and matches to the vehicle. sounds crazy but that is what i have read.
this si why my car is locked in my garage with the roll up door locked and dead bolted. it really sucks you can't have anything nice.
I have also had the security fix done to my Challenger from dealer to lock out the wifi and the PCM. sucks if I lose the key fob but that's on me. and the keys are locked in my safe as well.
we had some kids rummage thru some cars in the last few weeks as well. I leave nothing in my cars or trucks. if they want a box of Kleenex so, be it!!
thief's Suck!!
Thank you Kiddart
[Re: Kiddart]
#3097846
11/28/22 04:43 PM
11/28/22 04:43 PM
SNK-EYZ
A Red State
Update....
My brother talked to a dealer about the owners manual PIN and keyfob stuff.
They told him the cars PIN wouldn't be in the owners manual.
They also told him that they could put a red flag on keyfobs/keys being made in the vehicles history so no one could have a key made without proof of it being the vehicle owner.
They also told him that the could reprogram all the current fobs to a new code, for $120 each fob.
As far as his USPS (Postal) work ID, someone found it a few blocks from his house and dropped it into a mailbox (like it says to do on the ID) so it's being returned and is accounted for.
[Re: BloFish]
#3099107
12/02/22 11:09 PM
12/02/22 11:09 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Friend down the street had a few break ins with he Van at the GYM he runs. He finally had a person watch for days and finally this kid came back and he walked out opened the door grabbed the kid and the kids wallet. He said to him now you are going to clean my Van inside and out and put everything back. Kid started mouthing and that was it. I guess this kid could not read what was on the Vehicle with a rap that took up most of it. Brazilian Black Belt Jiu Jitsu, Taekwondo Black Belt, Black Belt Judo. UFC Traning Kickboxing Training. He said one twist of the kids arm changed the kids mind instantly. After the cleaning the kid got his wallet back and was never to be see again at or near the Gym. Thieves are getting more educated all the time and this internet is just one bad example of how to learn or buy things to be a thief.
1971 HEMI E BODY REGISTRY
