Re: Aluminum block
[Re: Thelma133]
#3094567
11/16/22 05:49 AM
11/16/22 05:49 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
How do you gents with aluminum blocks, with no petcocks, remove water from it for the winter?? I would drain the water from the radiator re-fill with antifreeze, run the block to temp and store for the winter, flush it in the spring.
Re: Aluminum block
[Re: RATTRAP]
#3094572
11/16/22 07:25 AM
11/16/22 07:25 AM
Posts: 10,038 MN
JERICOGTX
MN
Drill and tap a hole in the side of the block, and install a petcock.
My aluminum INDY block is half filled with Rock Block, and a hole was drilled at the top of the fill.
But as RATTRAP has said, just drain the radiator, and fill with antifreeze, and run the water pump to circulate.
69 GTX
68 Road Runner
Re: Aluminum block
[Re: JERICOGTX]
#3094575
11/16/22 08:07 AM
11/16/22 08:07 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
You can also blow compressed air in the upper hose and it will blow it out the lower. It would remove enough to not worry about freezing but won't get all of it.
68 Barracuda Formula S 340
Re: Aluminum block
[Re: RATTRAP]
#3094916
11/17/22 11:25 AM
11/17/22 11:25 AM
Posts: 16,928 NC
440Jim
NC
I agree. With the water pump running, it will mix the new antifreeze and the left over water in the block. So don't use that premixed antifreeze.
Re: Aluminum block
[Re: JERICOGTX]
#3094970
11/17/22 01:28 PM
11/17/22 01:28 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
But as RATTRAP has said, just drain the radiator, and fill with antifreeze, and run the water pump to circulate. 1) 2) as Al stated move some where warmer c) dont use coolannt - thats how I do it.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Aluminum block
[Re: Clanton]
#3095487
11/19/22 12:36 PM
11/19/22 12:36 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
I just winterized mine for the winter even though I have a heated garage. I do it every winter just in case my furnace were to break. I just drain most of the water and top off with antifreeze and fire it up until warm and circulating. Then drain it all in the spring again.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Aluminum block
[Re: moparx]
#3095723
11/20/22 10:52 AM
11/20/22 10:52 AM
Posts: 2,515 PA
moparacer
PA
Mine gets antifreeze no matter what....Being in the radiator business for 35 years, I have seen what a little water in the right spot can do if it freezes.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
