Insurance for "salvage title" car ?
#3093307
11/11/22 01:30 AM
11/11/22 01:30 AM
Posts: 3,821 New State
kidmopar
New State
Thinking of buying a "brand-X" car ( 2013 Ford Escape ) that was slightly rear-ended , however her insurance totaled the car for $3000.00 ........... About 100k on car everything else in great shape ....... I'm seeing very minimal damage to rear facia and small bump on lift-gate. she just wants the 3k for the car Haven't called yet ....... does anyone have experience getting salvage title car insured ? ? ? Thank you for any / all replies !
Re: Insurance for "salvage title" car ?
[Re: kidmopar]
#3093322
11/11/22 07:22 AM
11/11/22 07:22 AM
Posts: 19,991 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Here's what you need to do: - check with your insurance company (or other companies if yours won't) to find out what their requirements are for insuring a vehicle on a salvage title, or with salvage history. It is possible to do, though many companies that do so will require you to have the title changed from a salvage title to a rebuilt title. - If the latter is true, contact your state BMV to find out what steps need to be taken in order to have the title updated. For example, in Ohio, the OHSP must inspect the vehicle in person. They check the VIN, and that all safety items are working, and that the vehicle is roadworthy. Here's a link to Ohio's process, just for reference. https://services.dps.ohio.gov/vehicleInspection#!- Don't take as gospel anything anyone tells you about "I knew a guy,' or "I wouldn't worry about it," or "In state XYZ, we do this, so you should do the same." - with regard specifically to the 2013 Escape, if it has the 1.6 Ecoboost, it may not be worth buying, as they had significant engine and electrical problems. Our company fleet is made up largely of Escapes, and when the model change was made, our 1.6's were constantly in the shop, many for extended periods of time, many for weeks/months on end. Complete engine replacements, PCM failures, wiring harness replacement, etc.
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#3093334
11/11/22 08:58 AM
11/11/22 08:58 AM
Posts: 952 Central Michigan
nuthinbutmopar
Central Michigan
Here's what you need to do: - check with your insurance company (or other companies if yours won't) to find out what their requirements are for insuring a vehicle on a salvage title, or with salvage history. It is possible to do, though many companies that do so will require you to have the title changed from a salvage title to a rebuilt title. - If the latter is true, contact your state BMV to find out what steps need to be taken in order to have the title updated. For example, in Ohio, the OHSP must inspect the vehicle in person. They check the VIN, and that all safety items are working, and that the vehicle is roadworthy. Here's a link to Ohio's process, just for reference. https://services.dps.ohio.gov/vehicleInspection#!- Don't take as gospel anything anyone tells you about "I knew a guy,' or "I wouldn't worry about it," or "In state XYZ, we do this, so you should do the same." This is all you really need to know. I'll add that I bought a LOW mileage Rebuilt Title car for my business from a family that bought salvage cars and repaired them. They had pictures of the car before repair, and it was obvious they did quality work. They had a dealer license so the paperwork was 100% good. Insurance company didn't bat an eye, and the rate was exactly the same. Drove it for 3 years and 100k miles and got 90% of my money back.
[Re: nuthinbutmopar]
#3093431
11/11/22 12:58 PM
11/11/22 12:58 PM
Posts: 4,957 WI
Dcuda69
WI
Here's what you need to do: - check with your insurance company (or other companies if yours won't) to find out what their requirements are for insuring a vehicle on a salvage title, or with salvage history. It is possible to do, though many companies that do so will require you to have the title changed from a salvage title to a rebuilt title. - If the latter is true, contact your state BMV to find out what steps need to be taken in order to have the title updated. For example, in Ohio, the OHSP must inspect the vehicle in person. They check the VIN, and that all safety items are working, and that the vehicle is roadworthy. Here's a link to Ohio's process, just for reference. https://services.dps.ohio.gov/vehicleInspection#!- Don't take as gospel anything anyone tells you about "I knew a guy,' or "I wouldn't worry about it," or "In state XYZ, we do this, so you should do the same." This is all you really need to know. I'll add that I bought a LOW mileage Rebuilt Title car for my business from a family that bought salvage cars and repaired them. They had pictures of the car before repair, and it was obvious they did quality work. They had a dealer license so the paperwork was 100% good. Insurance company didn't bat an eye, and the rate was exactly the same. Drove it for 3 years and 100k miles and got 90% of my money back. Similar experience. Bought a Cavalier for my kid that already had a valid WI salvage title. Insurance company said nothing. Drove that little car for years. Traded it in and they gave us pretty close to what we paid for it. Zero issues.
#3093454
11/11/22 01:39 PM
11/11/22 01:39 PM
not_a_charger
Here's what you need to do: - check with your insurance company (or other companies if yours won't) to find out what their requirements are for insuring a vehicle on a salvage title, or with salvage history. It is possible to do, though many companies that do so will require you to have the title changed from a salvage title to a rebuilt title. - If the latter is true, contact your state BMV to find out what steps need to be taken in order to have the title updated. For example, in Ohio, the OHSP must inspect the vehicle in person. They check the VIN, and that all safety items are working, and that the vehicle is roadworthy. Here's a link to Ohio's process, just for reference. https://services.dps.ohio.gov/vehicleInspection#!- Don't take as gospel anything anyone tells you about "I knew a guy,' or "I wouldn't worry about it," or "In state XYZ, we do this, so you should do the same." This is all you really need to know. I'll add that I bought a LOW mileage Rebuilt Title car for my business from a family that bought salvage cars and repaired them. They had pictures of the car before repair, and it was obvious they did quality work. They had a dealer license so the paperwork was 100% good. Insurance company didn't bat an eye, and the rate was exactly the same. Drove it for 3 years and 100k miles and got 90% of my money back. Right. Some insurers don't care at all about a salvage title and will insure it regardless, some want you to get a rebuilt title, some won't touch it at all.
DBAP
[Re: Jim_Lusk]
#3093992
11/13/22 05:45 PM
11/13/22 05:45 PM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
I haven't kept up with the current trends, but it used to be a "salvage title" in IL meant the vehicle had to be rebuilt by a licensed rebuilder, then after it passed inspection, it was forever branded with a "rebuilt title". An insurance company salvage title means it was a car they considered as totaled that that have paid off the owner on. The salvage title allows the insurance co to sell that vehicle, and generally keeps it out of the hands of the general public until it has been repaired.
Now, a vehicle that has been "totaled" by an insurance company that has been bought back by the vehicle owner does not get a salvage title. The owner does not give up the title, he keeps it as it was. An insurance "total" simply means the insurance company deems that the repair cost is with in a % range of the value of the vehicle and is not worth repairing, as far as the insurance company is concerned. With older vehicles, it doesn't take much to reach the "totaled" price range of an insurance company. The damage to the vehicle could be completely cosmetic, and have nothing to do with the vehicle's function. I've bought and driven many insurance company "totaled" vehicles, some for several years and many miles.
Its the insurance company's choice on if they will insure a vehicle they have "totaled". Most will cover the vehicle for liability coverage only, until you prove the cosmetic repairs have been completed to their satisfaction. It the vehicle retains full coverage, it generally excludes the previously damaged area unless it has been repaired. It the insurance company totaled the vehicle because of a rear quarter panel damage, but the full covered vehicle was involved in a head on crash, they would pay for the value of the vehicle, less the amount paid out because of the previously damaged area, if those repairs were not made.
I bought a Dakota extended cab pick up a few years ago. The old guy driving it misjudged the distance to a parked car, and damaged the passenger side door, rear cab panel, and the front corner of the truck bed. The truck was a great truck, it just looked bad. I wanted to cover it for lability coverage only. My insurance wanted to put the truck in "high risk" because apparently, the police officer at the seen reported the truck looked "really bad". I drove the truck to my agent, and showed them the door still fully functioned, (it didn't even have much wind whistle through it)., and the truck was still fully functionally. My agent took pictures and documented that he agreed with me. They covered it for normal liability coverage. I drove that truck for 4 years, and the lady I sold it to is still driving it two years later. I suspect the truck was totaled by the old guy's insurance and he bought it back. I bought the truck from the old guy's grandson.
I can tell you lots of totaled vehicles that were bought back and delivered many more years of service. Those often make great winter beaters, or to and from work vehicles.
[Re: poorboy]
#3094022
11/13/22 09:01 PM
11/13/22 09:01 PM
Posts: 12,244 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Much of your post is correct. I'll just add a few fine points.
I have been a licensed rebuilder here in Illinois for decades. Contrary to common opinion, a salvage designation may have absolutely nothing to do with the condition of the vehicle. And often doesn't. Just one example; theft recovery. The vehicle may not have a scratch on it when recovered, but many insurance companies will 'salvage' it simply to sever any liabilities. They don't know what, if anything, happened to the vehicle during the theft.
There are tons and tons of reasons why an insurance company 'salvages' a vehicle. My neighbor told his insurance company that if they didn't 'total' his son's Camaro after a fender bender, he was taking all of his business elsewhere. He didn't want the young man to have it in the first place. Then there are salvages due to a lack of parts availability. I bought a really nice 300C last year that only needed a rear bumper assembly and quarter repair. But some of the parts were on back order. Then there are repair rejections. Customers won't accept the repair. And on and on. There are so many reasons that a vehicle may get a salvage title. And as I have already said, it may have nothing to do with the condition of the vehicle.
My experience with insurance on rebuilts is that most companies are fine with it. Illinois has issued a valid, negotiable title, and that is all they need to know. But occasionally a company will want an agreed to value, and once in a blue moon, a company will only go liability. But usually full coverage is not problem.
Master, again and still
[Re: DaveRS23]
#3094067
11/14/22 07:39 AM
11/14/22 07:39 AM
not_a_charger
ust one example; theft recovery. The vehicle may not have a scratch on it when recovered, but many insurance companies will 'salvage' it simply to sever any liabilities. They don't know what, if anything, happened to the vehicle during the theft. Insurers also total theft vehicles if they are unrecovered after a certain time frame, usually 30 days. This is per the policy contract with the insured, and is designed to facilitate prompt payment of the claim so that the insured can have the funds to replace the vehicle.
DBAP
