Re: New to me d100 truck [Re: poorboy] #3060034
07/17/22 09:12 PM
07/17/22 09:12 PM
houston texas
gremlinsteve Offline OP
houston texas
Gotta be the pump or in the fuel system leading to the tank
I have the pump on it now
Just gotta find out if it works now. The fuel filter is cruddy. Like there is trash in the tank
I fear it’s blocked in the tank at this point
I’m not able to blow air through the line due to the position of the truck
So that idear is out for now. Soon as I get the ac comp mounted I’ll test this pump
But when I removed it I got very little fuel out of the feed line
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: New to me d100 truck [Re: gremlinsteve] #3060380
07/18/22 09:11 PM
07/18/22 09:11 PM
houston texas
houston texas
Compressor is mounted
Re: New to me d100 truck [Re: gremlinsteve] #3062460
07/25/22 02:48 PM
07/25/22 02:48 PM
houston texas
houston texas
I have gotten the accessory drive installed belt lengths where tough to figure out but
I got it done
Here are some updated pics
Confessor core is also mounted and the underdash unit too. I’m going to start work on the hoses and the dryer next
Re: New to me d100 truck [Re: gremlinsteve] #3067518
08/12/22 11:21 PM
08/12/22 11:21 PM
houston texas
houston texas
Tossed on some stock valve covers
I like this look better than chrome
What do you think
Re: New to me d100 truck [Re: gremlinsteve] #3067771
08/14/22 06:22 AM
08/14/22 06:22 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Re: New to me d100 truck [Re: gremlinsteve] #3067784
08/14/22 08:46 AM
08/14/22 08:46 AM
Mo.
racerx Offline
racerx  Offline
Mo.
As i get older i tend to appreciate the classic looks of the mopar items.I like were this is going cool
Re: New to me d100 truck [Re: racerx] #3070906
08/23/22 09:30 PM
08/23/22 09:30 PM
houston texas
houston texas
Got my ac up and running today
Going to go with a higher amp alt to help it charge better at idle though
Voltage drops to 12.3 when at idle with the ac on
Re: New to me d100 truck [Re: gremlinsteve] #3087897
10/20/22 07:22 PM
10/20/22 07:22 PM
houston texas
houston texas
Got my gearvendor unit in this week
Re: New to me d100 truck [Re: gremlinsteve] #3088490
10/23/22 07:42 AM
10/23/22 07:42 AM
scratchnfotraction Offline
Make sure to smell oil
Ihave lost a couple bb enginesbefore with bad pump dumping fuel into crank case.
Check that oil or change it anyway to be safe.
Bb fuel pumps are known for dump fuel into crankcase.
